First drag run
Old Oct 14, 2007 | 10:35 PM
zx6r_gav's Avatar
Default First drag run
hi all i did my first drag at sydneys wsid dragway, did a 12.1 @ 113.23mph on my bog stock 95 zx6r with 86000kms on it, i weigh 92kgs or 202 pounds
i really wanted 11.9!!!!!
Old Oct 15, 2007 | 12:47 AM
meanstrk's Avatar
Default RE: First drag run
What was your reaction time? That is what was killing me when I went to the strip. I pulled a best of 11:07 and 124mph with the 600RR.
Old Oct 15, 2007 | 01:05 AM
05ZX6R's Avatar
It should be easy to gain that extra 2 tenths for a 11-sec time. Are you speed shifting or using the clutch? By speed shifting, I mean keeping your foot under the shifter with a little upwards pressure and when it comes time to shift just blip the throttle real quick and up shift to the next gear, no clutch needed. I still use the clutch for the 1-2 shift because it's easy to go to nuetral but speed shift the others.
Also what rpm are you launching at? I like to bring it to about 6000 and ride the clutch a little until I can let it out without bringing up the front. You could start at a higher rpm and ride it a little but I didn't want to glaze my clutch.
If it wasn't for the track rule of needing a leather suit for anything over 122 mph in the 1/4, I could probably get a real low 11 sec pass maybe even high 10 with a good launch. I bet you can get that 11.9 with that bike.
Old Oct 15, 2007 | 01:31 AM
kozumasbullitt's Avatar
ORIGINAL: meanstrk
reaction time doesnt hurt your et. the timmer only starts after your tires break the line.
Old Oct 15, 2007 | 05:16 AM
zx6r_gav's Avatar
ORIGINAL: 05ZX6R
yeah i was holding the revs at 8000 and dumped it a little too hard and monoed for a bit then it bogged down on me then went again.
i was using the clutch the whole time,
ill try again in about a month with a k&n filter and a -1 and maybe a +2 on the gearing
how much improvement will that make?
Old Oct 15, 2007 | 05:38 AM
ZX6Racer's Avatar
I have a 06 zx6r, my first time the strip i turned an 11.24 @ 123mph. Its all about the launch, I could not keep the front down. Next time i am going to lower the tire pressure and get up on the tank so i can launch harder. I made 5 runs, just could not get the start down. Ether I was pulling the front tire up or spining the rear to the 60' mark. By the way I live in Paradise CA and am looking for people to ride with.
Old Oct 15, 2007 | 02:45 PM
sounds like fun!! im in the bay area if you wanna ride sometime shoot me a pm.
ORIGINAL: ZX6Racer
Old Oct 15, 2007 | 05:00 PM
768 Ryda's Avatar
ORIGINAL: kozumasbullitt
ORIGINAL: meanstrk
yep that is correct, your 60ft is what is killin u bro, lower that 60ft and your times will drop, also straping the front will help and gearing, shoot for mid to low 1.7's on the 60ft and u will see low to mid 11's in the 1/4
spara
Aug 16, 2013 01:12 AM
lcpl0331
May 9, 2009 02:14 AM
illenium
Aug 31, 2008 12:28 AM
cmon6969
Oct 8, 2007 05:29 PM
c10
ZRX1200
Mar 1, 2005 04:35 PM
