2005 ZX-6R Speedometer Slow?
ORIGINAL: eztalking
I am not very failure with speedohealer or yellow box. I am assuming it mounts to the motorcycle and stays on the motorcycle? It is not something that will recalibrate the bike and can be removed? Is one better than another?? What price range do they normally run? Are they very hard to install?
ORIGINAL: MAD KAW
hey notstock, what size sprocket could i use to correct the speedo????
The speedo healer or yellow box are made to give you an accurate speedo. Plus when you do change spockets your set to adjust your speedo to the changes.
Sprocket changes kick *** and make your bike quick as hell but gives up top end. My R1 off the line makes me dizzy sometimes [sm=badbadbad.gif]
jhoffy22
Jun 20, 2011 05:50 AM
05, 2001, 2005, calibrate, calibrating, correction, healer, kawasaki, reset, speedo, speedometer, visible, zx636, zx6r, zx6rr
