Iridium plugs - CR9EIX
Just installed them today. Can't tell any difference. On the plus side they will last much longer then the standard plugs so I'll have to take all that crap apart less frequently.
Gapping iridium plugs is not recommended and not necessary. Well, at least that's what NGK says. It has to do with the iridium electrode being so thin that attempting to adjust the gap will likely end up snapping it. Also the spark is so hot that gapping it won't make any notable improvement.
The only time I ever noticed a difference using Iridium plugs was with my KLX250S. With the IX plugs the little motor came alive. It was noticeably more responsive. The difference was about the same when comparing properly jetting and stock setups.
I think its because the bike makes such little power anyhow (18hp stock) that ANY difference is noticed, even a 1hp difference would feel like a Turbo'd out Busa.
I'm at 6000 miles now and planning on 10K for the next service which should be in August. I will take lots of pics then to show the valve check/adjustment if you like.
FstaRockr Burns
05-21-2014 05:34 AM
seizetheday4eva
08-14-2012 04:25 AM
