another valve ajustment question
Old Oct 20, 2006 | 02:12 AM
my98_500r's Avatar
Default another valve ajustment question
Im about to take my bike apart to do a valve adjustment, and I need to know the specs on it if anyone has it. I know you all will say to buy a manual but Im doing this now. I will be buying a manual soon though. Thanks for any positive replies!
Old Oct 20, 2006 | 08:07 AM
jamieislimegreen's Avatar
Default RE: another valve ajustment question
I will just say good luck with it, do you already have the right tools? I just ordered the service manual the other day and hope to get it in soon
Old Oct 20, 2006 | 01:52 PM
my98_500r's Avatar
I have alot of tools and I have it apart already, I think I have the specs for it from Google and once I double check, Ill have it back together in no time.
Old Oct 20, 2006 | 02:04 PM
mozzerx's Avatar
Hey,
I did mine a few weeks ago - pretty straight-forward actually. Just take your time (double check your work) and you'll be fine. IF memory serves me correctly (VERIFY THIS INFO), the intake gap should be set between .005" and .007", while the exhaust gap between .007" and .009". there was a great write-up posted (with pictures) on ex500 riders.com before they went belly up. I saved the post in PDF format, so email me if you'd like me to send it to you. Final thought - try to get/use the pre-bent feeler guages - it makes things a bit easier.
Regardless, have fun and good luck.
Greg
mozzerx@yahoo.com
Incidentally, the credit deservedly goes to TONY REYES who took the time to help us all out by putting the information together.
Old Oct 20, 2006 | 11:40 PM
my98_500r's Avatar
ok..I emailed you for that .pdf. All I need now are the tolerances and Ill be good to go. This was much simpler than I thought it would be.
Old Oct 21, 2006 | 04:07 AM
mozzerx's Avatar
i emailed the pdf to you this morning - let me know if any problems.
Old Oct 21, 2006 | 05:40 AM
my98_500r's Avatar
I didnt get the email from you. My ISP sucks and I blame them. Either way IM almost done, me and my son were working on it and decided to take a lil break. I did find this though...
VALVE ADJUSTMENT
FOR THE EX 500 AND NINJA 500
Bill F.O.G. Martovich 08/13/03
This procedure is very simple and applies to almost any rocker arm engine. Few tools are required and they are simple ones at that.
Why: Valves are adjusted to maintain some clearance between the operating mechanism and the valve seat, to assure the valve closes on the seat for a good seal. If this fails to happen the engine will run poorly and damage could result. The amount of clearance is determined by the design of the valve train and the mfg. Experience as to wear life. Wear will usually decrease the clearance. (tighten) as the valve sinks deeper into the seat.
Generally the settings are done cold and allowance for heat expansion is included in the recommended settings. Deviating from these settings is a bad move, unless you know more than the manufacturer does (you don’t)
Tools required:
10 mm box wrench
Medium flat blade screwdriver
Feeler shims .005 .007 .009 two of each recommended
Procedure for EX500:
Drain the coolant (oils ok)
Remove the tank, right side coil, coolant pipes (the hoses can be left on).
Note: the carbs can be left on but it’s a lot easier if you remove them too.
Remove the cam valve cover
Remove the two copper oil lines
Remove the plugs in the left side engine cover
Remove the spark plugs (put a wad of paper towel in the cavity to prevent dropping something into the plugholes (this is a bad thing).
Using a 14mm socket wrench turn the engine over in a clockwise direction until the “C” mark on the flywheel is visible in the small inspection port and the cam lobes on the #1 cylinder face away from the rocker arms. (#1 is the right side as on the bike).
Note at this point the cam wheels will show the “IN” mark and the “EX” mark level with the cam box outboard surface (approx.)
Now to adjust the valves check with the feeler gages the space between the Adjusting screw and the top of the valve Intakes between .005-.007 Exhausts .007- .009 if they are within that range your golden (footsing around to make the perfect will gain you nothing).
The next cylinder: Rotate the crankshaft clockwise until the second piston is TDC and the cam lobes are pointing away from the valves. And check cyl#2.
If they are not: loosen the ten mm lock nuts (both) slip 2 feelers under each Screw and adjust hold the adjustment with the Screwdriver and tighten with the box wrench. This can cause the adjustment to change so check again. Using two feelers cancels any wear on the rocker arm to its shaft.
Turn the engine until the other cylinders cam lobes are pointing away from its valves and repeat steps above.
Recommended at this time to re torque the head bolts to 35 lbs.
Also remove and clean the “O” rings from the water pipes and the hole in the head they came out of. Reassemble with grease or RTV to prevent leaks
Tips: Setting the valves on the tight side will improve the engines performance and make it quieter, but shorten the inspection interval by ½
Reassemble.
Sources: Kawasaki manuals EN400 EN450 EX500 Supplement
~JOB COMPLETED and runs good.~
mr500
800, 800 Classic & 800 Drifter
Dec 3, 2012 11:01 AM
Ray11Ray
Apr 13, 2011 06:37 PM
scotty7676
Sep 30, 2009 02:08 AM
Ziguy
Feb 2, 2007 12:19 PM
