need track tires
Old Aug 22, 2007 | 02:24 PM
mnosbor's Avatar
Default RE: need track tires
CLICK HERE
Its racetechs info for the 250. Its actually $169. If your seals are good you shouldnt have to rebuild anything it can all be done from the top of the fork using the drain to remove the oil. You can even leave them on the bike. I had a bad seal and had to rebuild the forks. DO NOT USE GENERIC SEALS AND BUSHINGS. I tried a generic Vesrah seal and it was a nightmare because it got stuck half in and wouldnt come back out. I ended up having to replace the bushings because I trashed them getting the generic seal out.
Old Aug 22, 2007 | 02:28 PM
mnosbor's Avatar
ORIGINAL: fivepointnine
the only alternative is the EX500 isnt it? there arent too many bikes with forks as small as the 250, might be able to swap out the complete triple clamp/steering stem and forks with something, but that would take alot of measuring and research. I was thinking the emulaters were more around $250 or so....150 isnt so bad
Im pretty sure its not worth it for the ex500 front end. If I remember correctly theyre damper rod as well. Better time and $ invested in GVEs. You dont want to throw the handling of the bike off by changing its symmetry using a front end that may be longer than stock.
Old Aug 23, 2007 | 12:26 AM
Actually, was thinking more on the line of swapping out the triple tree that will use the stock head bearings. but yes, $150 is cheaper than that for sure.
olderthandirt
May 3, 2009 07:17 PM
44slider
Jul 30, 2008 09:32 PM
Roadrage
Ninja ZX-10R
Apr 9, 2008 07:55 PM
DeFran
15
Jun 5, 2007 12:32 PM
SAMCAR305
Feb 20, 2007 10:20 PM
