Clutch cover removal 2014 kx65
Old 09-04-2017, 10:25 PM
TORRAC's Avatar
Default Clutch cover removal 2014 kx65
Hey guys, My sons kx65 has been getting water in the oil. As I have understood that is fairly common on these. I have been trying to remove the cover and it will not budge off of the water impeller shaft. From the schematics, it appears there is a bearing pressed into the cover that I am assuming is also pressed on to the impeller shaft, thus holding it on. Any ideas, or am I overlooking the obvious? Thanks
Old 09-17-2017, 11:39 PM
BillandMary's Avatar
Unless the 65 is different from my daughters 85 and 100 there is no impeller behind the clutch cover only the water pump cover. I may be wrong but the water and oil shouldn't be in the same cavity.
71suburban
06-25-2017 02:38 AM
MattyTracks
02-14-2015 12:24 AM
copenrc
01-17-2012 03:39 PM
maxst420
03-29-2007 07:59 AM
Quick Reply: Clutch cover removal 2014 kx65
