Clutch cover removal 2014 kx65
Hey guys, My sons kx65 has been getting water in the oil. As I have understood that is fairly common on these. I have been trying to remove the cover and it will not budge off of the water impeller shaft. From the schematics, it appears there is a bearing pressed into the cover that I am assuming is also pressed on to the impeller shaft, thus holding it on. Any ideas, or am I overlooking the obvious? Thanks
Unless the 65 is different from my daughters 85 and 100 there is no impeller behind the clutch cover only the water pump cover. I may be wrong but the water and oil shouldn't be in the same cavity.
