where do my cables go?
Old 02-25-2009, 08:04 PM
jaylaudeman's Avatar
Default where do my cables go?
Ok so a couple months ago I took apart the front end to clean up and grease my stearing bearings. Well I'm trying to get it back together but I don't remember how my clutch cable and throttle cables were routed threw there. Does anyone have a picture or can explain where they route threw. Thanks
btw its an 07
Old 02-25-2009, 08:28 PM
I don't know if this helps, but a year and a half ago I did the same thing. Here are some pics, if you can glean anything from these then please do. Otherwise there will probably be someone on here that can also help.
Old 02-25-2009, 08:29 PM
I didn't take any cables off, I just lowered the headlight and spedo assembly. Did you take everything apart?
Old 02-25-2009, 08:52 PM
Yeah I took the bars off so i removed all that. So is the clutch cable coming up on the left side by the frame then comes up by that little hook that holds the throttle cables. Then thats where I am trying to figure out if it goes between the frame and black headlight cage and which side it comes out looking down towards your speedo
Old 02-26-2009, 01:45 AM
WestOzKLX's Avatar
Mine follows the route from the ring guide on the radiator guard snug next to the frame around the headtube and pops up under the speedo, between the black headlight frame and the speedo cable. Clear as mud.
This should help.
debby
10-13-2011 05:03 PM
ironfish
10-13-2010 07:29 AM
hellanbach
800, 800 Classic & 800 Drifter
06-27-2007 11:01 PM
cwgoff
04-03-2007 09:31 PM
ReaperFox
03-25-2007 05:26 PM
Quick Reply: where do my cables go?
