Gas tank damage from throttle cables
Old Mar 24, 2007 | 07:30 PM
ReaperFox's Avatar
Default Gas tank damage from throttle cables
Allo all.
Thought I'd drop a quick post and see if anyone else has had any problems and carry any advice to offer. On the underside of my gas tank I've found the throttle cables have rubbed against it enough that its completely rubbed through the tank and polished the metal of the gas tank to a near mirror shine running the length of the cables.
Needless to say its only a matter of time before rust devlopes and rust aside, over years it could possibly eat through the metal after replacing a cable or two. Have'nt found a convenient way to route the cables yet to keep pressure off the tank and don't know if warrenty will cover either issue.
Any advice?
Old Mar 24, 2007 | 07:59 PM
Default RE: Gas tank damage from throttle cables
Give us all a bit to check our tanks out, this could be an issue that we all need to address. Thanks for the heads up, we'll let you know.
Old Mar 24, 2007 | 08:27 PM
JB1's Avatar
JB1
Could you take a pic and post it?
How many miles do you have?
I didnt notice anything on my tank when I removed to re-jett the carb but mines only 3 months old.
Old Mar 25, 2007 | 01:03 AM
a16tony's Avatar
I put 'Chip Guard'(auto paint supply store) plastic film on everything that could rub the paint off my tanks. Under the tank you could use thin rubber and cement it over a wide area, or get a bed liner kit and coat the underside for permanent results.
Old Mar 25, 2007 | 01:33 AM
ReaperFox's Avatar
I'll post up a picture when I have time to pull the tank again, unfortionately that might be a few days, but I'll try to remember to get it done. I need to pull the tank to check a few things over anyways. Unfortionately my work week is about to start so I'm going to be real short on time for a bit.
Last I checked though the paint was rubbed entirely through and it was polished metal. :/
Old Mar 25, 2007 | 09:52 AM
TeamKLX250's Avatar
Is it still under warrenty? If so I'd take it to the dealer
Old Mar 25, 2007 | 05:26 PM
JB1's Avatar
JB1
Could you just take the right side panel off and take a pic?
MauiBoy808
Oct 6, 2018 05:23 PM
alky
Mar 28, 2017 06:16 PM
bigbrew
Apr 28, 2007 12:22 AM
cwgoff
Apr 3, 2007 09:31 PM
KAWABUNGA
23
Sep 24, 2006 10:09 PM
