What would happen......
Old Mar 28, 2007 | 08:45 PM
Ginsu4u's Avatar
Default What would happen......
if I ran a 35 watt heated vest off the battery? Would I fry something? If I shut the vest off a few miles from my destination, would that give the battery enough time to charge back up? I know we have discussed this before, I just cant remember what the conclusion was. Thanks in advance.
Old Mar 29, 2007 | 12:31 AM
bmwhd's Avatar
Default RE: What would happen......
You have at least 40 watts to spare so no problem.
Old Mar 29, 2007 | 12:06 PM
tremor38's Avatar
I have tested this under real world conditions.
You can run most heated vests with no worries. The charging system will keep up. You will have to watch things a bit closer if you try to run a vest and heated grips at the same time though. Also, thepower consumption ratings on most devices are a bit on the'modest' side shall we say. EverythingI have tested so far consumes more than what it is rated at. A 35W vest will probably draw in excess of 40W,but that should be no problem. I tested the bike out with a 55Wautomotive head light that actuallyconsumed about 68W and the bike held up fine (no battery discharge).
The battery began toslowlydischarge when I turned-on both the 55W light anda pair ofheated grips.
Switching to and H4 based HID headlight will free-up another 20W. That will be on my list for next season[8D]
ORIGINAL: Ginsu4u
Old Mar 29, 2007 | 12:49 PM
TeamKLX250's Avatar
An LED taillight would help there too
Old Mar 29, 2007 | 01:17 PM
tremor38's Avatar
Yup! Already got one of those.
ORIGINAL: TeamKLX250
Old Mar 29, 2007 | 02:33 PM
TeamKLX250's Avatar
ORIGINAL: tremor38
Yeah I was telling Ginsu4u
Old Mar 29, 2007 | 05:01 PM
Ginsu4u's Avatar
Great!! Thanks for the info. I will be installing an acc plug today then. I will also look into the LED brake light. Do you guys know of a good one, on a budget?
Old Mar 29, 2007 | 05:28 PM
ORIGINAL: bmwhd
Hey Todd.....
Old Mar 29, 2007 | 05:30 PM
ORIGINAL: Ginsu4u
As in a 12 cigarette plug? Good, then you can make a pigtail from a battery tender and top off the battery once in a while without having to pull panels off of the bike. Also makes for a nice way to jump start between bikes.
Old Mar 29, 2007 | 05:45 PM
Ginsu4u's Avatar
I have a battery tender. The plug comes out the back near the coolant resevoir. I think an acc plug will be the best. That way I can run the I-Pod off of that this summer. Now I just need that I-Pod with video so I can watch Long Way Round while I'm riding....lol.
deej
Dec 14, 2007 07:35 PM
frrogger1
Aug 23, 2006 08:03 AM
SERGE
May 23, 2006 02:24 AM
SERGE
May 22, 2006 09:48 PM
crash972
Sep 19, 2005 06:34 PM
