What headlight is this?
And the winner is.......
Acerbis Dimension
CERTIFIED
HEADLIGHT
> DIMENSION
TECHNICAL CHARACTERISTICS
The new two-color headlight used for racing is the most
recognized in the market. ECE, DOT and SAE Certifi ed.
TÜV construction Certifi cation.
• Headlamp with 12V 35/35 W incandescent light bulb,
12V 4W position
• Height of light beam is easily adjustable with a handle
on the back of the lamp
• Mounted with two rubber straps that secure it to the
front fork in two optional positions
• The position of the mounting points allows ample room
for the brake cable
• Comes with light bulbs and adhesive number plate
sticker (sticker must be applied)
• Weight 435 gr.
Too easy!
Acerbis Dimension
CERTIFIED
HEADLIGHT
> DIMENSION
12V 4W position
for the brake cable
• Weight 435 gr.
Too easy!
So what is the 4w bulb for? I have one in my UFO headlight as well. I hooked it up to the high beam circuit. Is this like a required driving lamp for Europe?
ORIGINAL: 2k1w=no$
Used to be on bikes here but now the headlight can't be turned off so it's not required.
Thad-deus Coan
Sep 14, 2012 04:32 PM
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
