What headlight is this?
Old Jul 7, 2008 | 10:28 AM
neilaction's Avatar
Default What headlight is this?
Does anyone recognise this headlight set up?
http://www.kawasaki.com.au/kawpublic...nsRide&Why.pdf
Old Jul 7, 2008 | 12:28 PM
WestOzKLX's Avatar
Default RE: What headlight is this?
And the winner is.......
Acerbis Dimension
CERTIFIED
HEADLIGHT
> DIMENSION
TECHNICAL CHARACTERISTICS
The new two-color headlight used for racing is the most
recognized in the market. ECE, DOT and SAE Certifi ed.
TÜV construction Certifi cation.
• Headlamp with 12V 35/35 W incandescent light bulb,
12V 4W position
• Height of light beam is easily adjustable with a handle
on the back of the lamp
• Mounted with two rubber straps that secure it to the
front fork in two optional positions
• The position of the mounting points allows ample room
for the brake cable
• Comes with light bulbs and adhesive number plate
sticker (sticker must be applied)
• Weight 435 gr.
Too easy!
Old Jul 7, 2008 | 02:33 PM
neilaction's Avatar
Old Jul 7, 2008 | 02:48 PM
i just put a new headlight H4 conversion on my CB750..... much more better.....
Old Jul 7, 2008 | 04:18 PM
2k1w=no$'s Avatar
So what is the 4w bulb for? I have one in my UFO headlight as well. I hooked it up to the high beam circuit. Is this like a required driving lamp for Europe?
Old Jul 8, 2008 | 01:44 AM
neilaction's Avatar
ORIGINAL: 2k1w=no$
Parking light I would think.
Used to be on bikes here but now the headlight can't be turned off so it's not required.
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
Savagekilla
May 16, 2008 10:22 PM
MARK
KLX125 & KLX125L
Aug 21, 2007 02:08 AM
vulcanguy
Apr 2, 2006 11:10 PM
