Tuning the TM36 on the fly
Old Dec 13, 2014 | 07:48 PM
Richard Avatar's Avatar
Ya the smart phone speedometer apps are sketchy in performance. I don't want to be beating on the bike only to get inaccurate info. Once the shift light is on, it'll be a no brainer-almost as good as a Veypor. (the plate that holds the stopwatch is bolted to the RH turn signal stalk)
What is it you are vibrating at work?
Old Dec 13, 2014 | 08:43 PM
Re that vertical divider I tried earlier..if that slows the bike by 3 seconds, imagine what that Thunder Products quad wing torque insert does ?
It has to be hurting performance
Old Dec 13, 2014 | 10:31 PM
MattyTracks's Avatar
Talking
Equipment health monitoring, example; we get a new pump/motor assembly, we install it and trial it, during trials we measure axial and radial vibrations at major components(bearings, shafts, gearboxes, pump end bearings etc) then every X hours of operation we re measure these points, compare the values with baseline and determine if we need to replace or repair components. Vibration analysis(VA) has endless applications in industry, or marine engineering in my case.
pwjm
Aug 11, 2015 10:28 PM
klx-vn
Jun 9, 2015 03:16 PM
dngrrngr
May 7, 2009 02:15 PM
exalted512
Ninja 500R
Oct 22, 2007 01:18 AM
greenmachine
Jun 15, 2006 06:31 AM
