So I am putting together a tool kit to take out with me on the trail. I would rather not carry a ton of tools so I am trying to see what I actually need. I went through the tool kit and it looks like that covers 99% of what I need. The only thing I found it lacking were tire irons and wrenches big enough to get the rear axle off so I bought the spoon/tire iron combo in size 22mm & 27mm. Now I have tire irons and axle wrenches.
From the stock tool kit I gathered I have:
- flat head and phillips screw driver
- 10, 12, 14, 17 open ended wrenches
- 8, 10, 12, 14 socket
- Pliers
- spark plug tool
- suspension adjustment tool
Besides the obvious:
- zip ties
- extra wire
- duct tape
- extra fuel line
- hose clamps
- safety wire
- bicycle derailleur wire
- Quick steel
-Chain master link
- multi-tool
- electrical tape
- patch kit
- tire pressure gage
- C02 Cartridges
For Multiday trips:
- radiator stop leak
What other tools do I need?
Also, from the stock tool kit, I believe the big hook looking tool is for the rear suspension adjustment. What is the square in the handle for? And then what is the tool on the top I am holding? An extension?
How are you planning on getting the rear wheel off?
I would ditch the CO2 & just take a air pump. Do you know how many CO2's you need to fill the tire? And once they are used, they are useless.
Ditch the spark plug & suspension tools, bicycle wire (don't know what that could possibly be used for).
I would make up a premade jumper cable with alligator clips to jump the bike/battery.
I lieu of a mini tool, I have a small hand ratchet with phillips/straight/hex heads, pick one up at HF.
A assortment of metric nuts/bolts.
An alternative to all those wheel removal & tire repair tools is go 'tubliss' and bring only zip ties and slime.
Have you ever patched a tube?
--to get the rear wheel off I have 22mm & 27mm axle wrenches & tire irons, what else do I need?
- My CO2 is a pump/C02 combo. been using it for years to fix flats on my MTB bike. it will take 1 CO2 to do the front, 2 to do the rear. Should be enough to get me out of the woods
I think that tool above is supposed to be for the rear spring adjustment, but I found it less than useful.
The spare bolts and nuts mentioned by durielk should definitely go in the kit. Consider adding spare brake and clutch levers and a shifter. Find a place on the bike where these can be zip tied or safety wired on, like the up-facing side of a skid plate. Some guys will get a spare clutch cable and tie it to the existing one so it's already in place. Add a front tube. It can be used for the rear in an emergency. Include talcum power and dish soap for mounting the tire. Nitrile gloves.
I've been on a ride where an atv mangled their chain. So two master links n spare short piece of chain and a
good quality chain breaker were added on long rides primarily.
I broke my collar bone at a desert night race off the 15 fwy n I was glad someone there gave me a 800 ibuprofen so I add that too.... Mainly try to pack it a tool belt or a small back pack instead of adding to the bike so much.
I can see if your racing caring stuff in a back pack, but..... I ride with a camel back for liguid refreshment, and I would not want a back pack with all those tools, spare parts, spare gas, etc. on my back. I know guys do it, but that would be HELL for me.
I ran out of gas 10 miles short on a DS ride, this other rider pulled a gallon of gas out of his backpack. That was crazy! but I'm glad he had it!
I've broke a MBike chain, but never had any chain problems besides that, and not planning on it.
