TM36-68 Throttle Position Sensor?
Old Feb 21, 2024 | 06:36 PM
Oldboy's Avatar
Default TM36-68 Throttle Position Sensor?
I am finally getting around to installing the new TM36-68 pumper carb on my 2007 KLX BB351kitted bike. I noticed that the original CVK carb has an electrical connector that is the throttle position sensor. There is NOT a provision on the TM36 carb for that sensor. I assume that someone who has replaced the CVK carb with the TM36 pumper has already addressed this issue so I am asking for advice. Do I just wire the two wires from the connector together and install the TM36 as it is without a TP sensor?
Help will be appreciated.
Old Feb 22, 2024 | 01:08 PM
1994klr250's Avatar
You can install the TM36-68 pumper carb without the throttle position sensor. No need to do anything with the plug. I have the same carb on my 06 klx with a 351 big bore kit and it runs perfectly fine.
Old Feb 22, 2024 | 06:29 PM
Oldboy's Avatar
Thanks for the response. I installed it and it runs great! I appreciated the information as I didn't want to install the carb before I knew that answer.
outrecording
Jul 9, 2023 03:48 PM
Nuvorigo_uk
Jan 31, 2015 04:16 PM
2006klx250
Mar 23, 2011 09:25 PM
jman
Jul 19, 2007 03:22 AM
Ziguy
Feb 7, 2007 04:27 AM
