Ticking sound worse when cold
Old Aug 31, 2020 | 05:09 PM
Unfortunatelywrenching's Avatar
Default Ticking sound worse when cold
So my 06 klx 250 has started ticking, I think its the cam chain Tensioner because it sounds like a cam chain (I put a stethoscope to it) and that seems to be a very frequent problem with these bikes but its far louder when its cold and its worse at idle which I haven’t seen described here as a symptom of the tensioner going, so before I go order a part that might not fix my issue I thought I’d post here and see if anyone could guve me some insight.
Old Aug 31, 2020 | 10:13 PM
Makes sense, after all as the engine warms up everything grows a bit, taking up a bit of the slack in the cam drive. If you found the noise loudest at the tensioner and cam drive it is the tensioner. If louder up around the cam cover it is valve clearance.
As you may or may not know, I make the KLX250 tensioners and you can PM me. Don't buy on ebay, I charge an extra $4 for the fees on there and both of us pay more. I will also say replacing the tensioner is the least expensive non-invasive change you can make to see if the drive is loose or is something else.
Old Sep 1, 2020 | 04:47 PM
I would say its probably a bit louder up top but its got a more distinct sound right by the Tensioner bolts, have no clue which it is lol
Old Sep 1, 2020 | 10:14 PM
So.... what do you think that is telling you?
Radianrider
May 20, 2020 10:18 PM
Chathushka nandun
Sep 11, 2019 04:21 PM
s10gto
Jul 3, 2016 11:39 PM
Illking
Oct 5, 2011 11:52 PM
