Front forks
Old Jul 12, 2020 | 11:46 AM
philgoodklx's Avatar
Default Front forks
Anybody in the UK got a clean pair for sale to fit my 2009 klx250s?
Mine have aluminium cancer and may well need replacing.
Thanks
Old Jul 13, 2020 | 06:16 AM
May have found a 2014 D Tracker front end. Does anyone know if this is the same and/or will slot straight into my 2009 klx? Thanks once again.
Old Jul 16, 2020 | 11:36 PM
OzNoob's Avatar
Same part number from what i can tell, whether they are identical is another matter but i think you will be fine.
Old Jul 17, 2020 | 08:09 AM
Thanks. My pal has looked at mine and reckons it's only chrome flake atm.
Old Jul 17, 2020 | 11:17 AM
OzNoob's Avatar
Thats how it starts.
Maybe spray some acid neutralizing wash or similar in case it gets worse.
If the surface is peeling it will get worse with time.
Old Jul 18, 2020 | 08:55 AM
Cheers Oz. Will look into that.
Old Sep 3, 2020 | 02:42 PM
zl PINHEAD lz's Avatar
Thanks
I'm having the same issue right now and I've been searching high and low for a while for a set of forks or even a front right leg but I'm not having any luck atm.
Have you had any success in fitting D tracker forks? did you get D Tracker 250 forks as there is also a 125 version?
I barely ride these days with the serious condition of the fork and DO NOT want an accident.
Any info will be appreciated.
Old Sep 3, 2020 | 02:46 PM
My pal had a look at mine and said it's only surface rust so haven't done anything about it.
Didn't follow up the d tracker forks.
Old Sep 3, 2020 | 02:54 PM
Ah, no worries, thanks for a quick reply mate.
cpr1
Jun 8, 2011 03:49 PM
YANK
Apr 25, 2011 12:04 AM
cpr1
Oct 14, 2010 04:42 PM
avalaugh
ZZR 600
Jun 7, 2008 12:20 PM
foggys916
Oct 5, 2007 05:24 PM
