Suspension question
Old Nov 28, 2007 | 01:35 AM
2k1w=no$'s Avatar
Default RE: Suspension question
Gerry, your rearsag should be set pretty much correctfron the factory. I weigh a little more than you, and when I first checked sag it was in the correct range.In the front the adjusters for compression are at the bottom of the forks(underneath). I think they have caps on them. I would go more than 1 click at a time on the front. Mine were set at 12 or more clicks out from the factory and I am down to 4 out right now. Your on your own with the rear shock though. It is also good the periodiacly jack the bike up off the ground(front wheel in the air)and open the screws that are on top of the forks to bleed off any pressure that has built up in the forks. Just take the screw out and then put it back in.
Old Nov 28, 2007 | 12:54 PM
mudjunkie's Avatar
2k1w=no$,
I was also reading about this in the manual, but don't recall whether or not you have to bounce the front end a few times before jacking it up? or do you simply jack it up and bleed off the pressure? I know it said the more the front spings are bounced the stiffer they get.
Old Nov 30, 2007 | 02:16 AM
gerrynolan's Avatar
ORIGINAL: 2k1w=no$
Thanks! So To match your front compression, would I turn clockwise all the way and then back out 4 clicks each? Will that reduce the amount that the front "dives" when I hit the Front Brake? (that almost wiped me out today) I also don't want to make My KLX land way harder from jumps. Thanks again!
Old Nov 30, 2007 | 02:46 AM
KLXer's Avatar
ORIGINAL: gerrynolan
If you increase compression dampening it will have more of an effect of making the front end harsher on jumps than eliminating brake dive ,so no. Dampening is no replacement for springs. Jumping is a faster fork action so the compression dampening will firm that up somewhat. A slower motion, like brake dive, you need springs.
cegusman
May 26, 2012 12:24 AM
Zx14rider
Ninja ZX-14
Mar 24, 2007 07:42 PM
Gomerpile
Jan 18, 2007 08:10 AM
aszrael1266
Oct 19, 2006 10:00 PM
qforty5
Ninja ZX-7R
Apr 2, 2006 10:59 AM
