starter idler gear bushing worn at one side.
Old Jun 16, 2017 | 11:19 PM
durielk's Avatar
Originally Posted by Brewster
A flange remains.
I don't know what this means.
Anyway, that OP & my bushing only has load on it when the starter is engaged. So if you get something to work for the bushing, it should last for quite a while if you don't use the starter a lot.
I think they must have had a bad run of those bushings for some reason.
Old Jun 16, 2017 | 11:24 PM
Brewster's Avatar
It's a reply to your previous post, #9.
Ride on
Brewster
Old Jun 17, 2017 | 11:42 AM
Subseageorge's Avatar
My collar / Bushing was OD 14mm Id 10mm.
The one that came out.
I made the same size although i think i will make another one with a tighter tolerance on the ID.
This will do temporarily
I managed to get a piece of Stock Bronze. ($15)
Then when i went to borrow the lathe the machinist (IF that is what you call them offered to do it for me for $ 2 ) That included making some pre-load spacers from PTFE for my fork springs. 5mm / 10mm /15mm and 20 mm.
vtvette
Feb 7, 2022 02:31 PM
Broussard
Mar 31, 2021 08:25 PM
gjones
KX250 & KX250F
Apr 14, 2015 05:13 PM
bruballer54
KLX300R
Jun 5, 2007 12:00 PM
LordVngr
Sep 4, 2006 08:21 PM
