Slight cracking/impurity?
Old Jun 24, 2017 | 01:46 AM
Dirtrider4207's Avatar
Default Slight cracking/impurity?
So I just did the first oil change on my klx, and when I pulled the filter I noticed 2 things........
1 - the back of the case on the engine looks and feels like there is slight hairline cracking from the middle heading towards the outer edges.
2 - there was a spring on the front of the filter that shot the old one out with great force. I can't seem to get the new filter back in with that spring balanceday on top and the filter seems to fit just fine without the spring. Could the spring be the cause of the potential cracks? It the spring necessary?
I can't seem to upload the pictures for some reason but it will keep trying. Thanks for any advice/help in advance.
Old Jun 24, 2017 | 02:33 AM
GBAUTO's Avatar
It's probably just casting flash. The spring is important. I 'adjusted' the base of the spring to stay attached to the cover-works just fine.
Old Jun 24, 2017 | 05:10 AM
outrecording's Avatar
What GBAUTO said. I used to use a small dab of grease to hold the spring in place but eventually bent/opened the spring a bit at the base and it holds nicely in place
Old Jun 24, 2017 | 11:59 AM
MaverickAus's Avatar
Correct, small bend will hold it in place
Old Jun 24, 2017 | 04:39 PM
snappster's Avatar
Picture of the crack like feature in question would be helpful.
Old Jun 30, 2017 | 10:20 PM
Can't get a pic on here to save my life, but I did have the shop look into it for me and was assured it's not cracking or anything to worry about. I did get the spring back in place after much trial and error. Next time I will use the grease tactic for sure. Thankso for the help
Old Jul 1, 2017 | 12:13 AM
s10gto's Avatar
Its just casting flash. I have seen it also.
darkmarc
Aug 24, 2013 09:37 PM
Beachrider
Aug 17, 2012 03:18 PM
Redlinejohn
Aug 21, 2007 02:14 AM
beachjn
May 28, 2007 01:01 PM
xyz1000rr
Ninja ZX-9R
Feb 14, 2007 06:26 PM
