Rear Inner Tube size for stock 2006 klx250s tire?
Old Jun 30, 2017 | 01:24 AM
ramsey.mangus's Avatar
Default Rear Inner Tube size for stock 2006 klx250s tire?
valve stem ripped
Old Jun 30, 2017 | 03:39 AM
MaverickAus's Avatar
Old Jun 30, 2017 | 10:19 AM
klxnoobie's Avatar
Pick up a set of these for front and rear tire https://www.rockymountainatvmc.com/p...n-Pro-Rim-Lock should prevent that from happening again.
Old Jun 30, 2017 | 12:35 PM
Make sure you leave the valve nut loose, I ripped 2 valves (one a heavy duty) before I learned. Of course it never happened until I ran lower air pressure for off roading.
Old Jun 30, 2017 | 12:36 PM
I had no idea... How loose??
Old Jun 30, 2017 | 01:39 PM
Abramsgunner's Avatar
Also be aware, adding rimlocks will throw your tire balance seriously out-of-whack for street riding; so either add two to each wheel, or order some spoke weights at the same time. I ended up with Motion Pro Litelocs and only needed a couple ounces of weights per wheel (vs. 4 or 5 for the heavier locks). I used wieghts from 'THE REUSABLE SPOKE WEIGHT STORE' on fleabay... good stuff.
As for 'How loose?", just run the nut up to the cap on the schrader valve. Every now and again, take a look at the valve and see if it is at an angle... that way you know when your tire is rotating on the rim and can correct it before losing the stem.
Old Jun 30, 2017 | 01:58 PM
Originally Posted by ramsey.mangus
valve stem ripped
You asked about size in the title. If you need it, most tubes are multi size due to the obvious stretch in rubber. If you get one that will work with a fit for 4.00, 4.50, 110 or 120 in the labeling you will be good to go.
As for the rest, follow what the others have said.
Old Jun 30, 2017 | 11:37 PM
Thumbs up
Good post I forgot to mention the balance after fitting rim locks
Old Jul 1, 2017 | 01:30 PM
klxnoobie's Avatar
Solder wrapped around the spokes https://www.lowes.com/pd/Worthington...Solder/3829727 makes a pretty good balance weight
AZR
Sep 1, 2013 01:47 PM
cegusman
Jun 15, 2011 06:49 PM
mouka
Aug 4, 2009 01:22 AM
steve10
Apr 17, 2008 03:56 PM
fireroad
Jul 13, 2007 09:16 AM
