Shifting issues with my KLX
Old Jul 3, 2018 | 01:30 AM
Don Tripas's Avatar
Default Shifting issues with my KLX
Sooo .....
This weekend when parking on a hill, I dropped my 09 KLX250s very lightly on its left side with me on it. On my ride home today, I noticed the shifting was acting strange. This was the first time I had ridden the bike sine the drop. It became difficult to shift up from 2nd to 3rd and from 5th to 6th..... Like I really had to put some muscle into it. 5th to 6th wasn't as bad as shifting up from 2nd but still kind of sticky. No issues shifting down.
Previously to this, I had an issue where when I came to a stop in 1st or even 2nd gear, after shifting down from speeds up to 50mph, my bike wouldn't shift out of gear unless I lightly released the clutch to accelerate forward.
On top of this, my bike must of stalled at least 4 times today on the ride when stopped in gear at red lights.
Ive read about the pin on the shift star breaking when dropping the KLX on its left side. Even more, I've read that the 09 specifically has issues with its shift star. Could this be the issue with my 09 KLX?
Are my two issues connected? Or is the stalling issue separate from the shift star issue?
Thanks ahead of time
Old Jul 3, 2018 | 01:58 AM
GBAUTO's Avatar
https://www.kawasakiforums.com/forum...ar-gone-34237/
This is a common problem if the shifter gets a hard impact.
Old Jul 3, 2018 | 02:24 AM
Don Tripas's Avatar
Got it! Thanks a mili
Old Jul 3, 2018 | 01:35 PM
GBAUTO's Avatar
This shows the offending pin as well as the shifter star. It's a simple job, just make sure that the collared washer that fits over the shift shaft is seated into the pawl before tightening the cover. If it doesn't want to sit flush with the case, DON'T tighten it-you will crack the cover.
Old Jul 3, 2018 | 02:58 PM
Don Tripas's Avatar
Still having issues with it stalling when im sitting in idle at 1000rpm. Ill have keep rev'd above 2000rpm to keep it from dying.
Thinking maybe its my battery? or a fuse ..... because I noticed the time on the clock had changed after it died. Any tips?
Old Jul 3, 2018 | 03:09 PM
Don Tripas's Avatar
Thanks. It looks like an easy fix. I found a nice how to video on youtube.
Old Jul 3, 2018 | 11:13 PM
durielk's Avatar
Thinking maybe its my battery? or a fuse.
I'm thinking carb, if you have one. When a fuse goes, it is gone, no maybe, buts or otherwise. If the battery is starting the bike, that probably isn't it. Now, you may have a loose connection somewhere.
Old Jul 4, 2018 | 01:34 AM
Don Tripas's Avatar
Would you be open to sharing your phone number via private message? I just shot a 2 min iphone vid to help diagnose the issue. I can send it to you? Or anyone who is willing to help.
Thanks
Old Nov 29, 2020 | 03:33 AM
ekim250's Avatar
Do you have a link to this video?
Old Dec 2, 2020 | 06:41 AM
dtrackermslazgromthailassi's Avatar
I hope it's this one because I think it just broke on mine. can't shift to 1st and lever goes too down.
Gwolf
Jun 1, 2017 02:40 AM
Matt88-8
Feb 22, 2017 04:56 PM
roadglider
Apr 26, 2011 11:32 PM
zx7rydr
Jul 22, 2009 03:32 AM
IQOUTLAW
Mar 31, 2009 05:53 AM
