Rear Fender Options
Old 07-18-2013, 04:54 PM
zl PINHEAD lz's Avatar
Not sure if this is what your after, but this mod looks pretty cool
Or you could maybe go for a small tail light like the DRC Edge
Old 07-18-2013, 06:59 PM
ahnh666's Avatar
black fender...plastic can be cut and you can always mount the lights and plate above, but not sure if it'll look good since the 09+ rear fender sits flatter
Originally Posted by tjrockit
Thank you for the offer. Let me think about it. Is the fender black or green?
A few of the guys I ride with have a similar setup and they often are zip tying the plate back on after a get off. That's why I'm trying to get it on top of the fender.
Old 07-18-2013, 07:07 PM
tjrockit's Avatar
Very cool, I like the black.
I appreciate everyone's feedback and advice.
So back to the original question, does anyone know if the 06/07 rear fender is a direct bolt on to the 09?
Old 07-18-2013, 09:10 PM
wildcard's Avatar
highly doubt it. I believe the subframe is quite different in addiion to the body work.
but anything could be made to fit with enough work.
Old 07-19-2013, 11:54 AM
tjrockit's Avatar
brilliant!! I didn't think to check the subframe part number. 2009+ have a /A appended to it.
Old 08-14-2013, 02:43 AM
fenderworks2's Avatar
Default Fender
so TJrockit
have you found a solution for the 2006 klx250 rear fender?
wondering what you have done.
I think I am going to just remove all that crap and mount my plate under the red tail light, keeping stock blinkers. it will not have a white light on the plate, but might still be ok
fenderworks
glenwood springs, co
Old 08-14-2013, 06:02 AM
turnsleft's Avatar
Some aluminum, a drill and some nuts and bolts. I broke mine a few times. Then cut the black plastic off even with the bottom of the tail light made some bends and drilled some holes through the cross piece. I did three but would just go with two if I were to do it again.
Brieninsac
09-10-2020 05:47 PM
Werloc
06-29-2015 09:23 PM
vurtle
06-09-2007 04:02 AM
JazZ023
07-25-2006 06:32 AM
tennisman
02-26-2006 07:05 AM
Quick Reply: Rear Fender Options
