Propblem shifting into first gear
Old May 28, 2011 | 09:08 AM
CousinLarry's Avatar
Wow, pretty awesome that using a certain oil brand can change your gear ratios!! That's some sort of witchcraft or something. hahahaaaa ...
Man, people have some crazy beliefs when it comes to oil!
Old May 28, 2011 | 09:30 AM
Originally Posted by ACOLE
So you don't subscribe to the theory that better lubrication results in the engine working better with less friction therefore resulting in less energy required to produce power.
Yes, but same rpm = same speed ... unless the clutch is slipping.
Old May 28, 2011 | 10:02 PM
I 100% agree with your second statement here, but it's not the same as your statement about rpm's related to your speed. You're making two different points.
Your engine , transmission, drive train, are all mechanical devices manufactured to tight tolerances, with almost zero play/slop. The only place you could have anything slipping is, as FM mentioned, in the clutch (that shouldn't be slipping if it's in proper working order)
Picture two sprockets of the same size connected by a chain. One rpm on the front sprocket will result in one rpm on the rear sprocket. No way to get any other result. You could cover those sprockets and chain with mud, cookie dough, or baby oil and one revolution on the front will get you one revolution on the back. Clean well oiled sprockets and chain will be easier to turn, (use less gasoline) but rpm to speed cannot change.
As I said in my first post, you could possibly see better mileage with a different motor oil, that would jibe with your second statement.
Dan
Old May 29, 2011 | 12:47 AM
maninthesea's Avatar
Note: It is not a good idea to sit at the lights in neutral with the clutch pulled in and then try and engage first gear. ( Not that any of us would do that)
Cant see why you would want to sit in neutral with the clutch in for any length of time but I also dont see the harm. Can you explain?
Old May 29, 2011 | 03:32 AM
ACOLE's Avatar
Was just suggesting not to hold the clutch in while in neutral (Say sitting at lights) and that if you do hold the clutch in for a while and then select first at least on my bike it will graunch.
Old May 29, 2011 | 03:04 PM
If you stopped and are not in 1st gear, all you have to do is put a slight toe weight on the shifter and let the clutch out slightly and it will pop right in.
wildcard
Jul 26, 2010 02:39 PM
OR-guy
Jun 24, 2009 02:15 PM
tedphips23
Sep 20, 2008 06:28 AM
drifterman
Sep 27, 2007 01:53 AM
asudevil1881
Ninja 650R
Feb 7, 2007 04:25 PM
