Pro Taper SE handlebars...
Old Apr 5, 2007 | 04:20 PM
double d6's Avatar
Default Pro Taper SE handlebars...
Anyone have the Pro Taper SE's and have any trouble with aftermarket handguard fit issues?
I found that since the bar is so much thicker, the inside diameter is way smaller than stock and my BENT[:@]moose bars. So much so, that I can't get any of the included hardware to fit inside. If I just go and buy some nuts and bolts with an appropriatesized rubber hose, that would be ok.....NO?
Just having trouble finding the hose.
Anyone been through this and would like to throw some info around.....I would be thankfull.
Dave
Old Apr 5, 2007 | 05:07 PM
KLXer's Avatar
Default RE: Pro Taper SE handlebars...
Get a bar end kit for aluminum bars. They are all that way.
Old Apr 5, 2007 | 06:59 PM
bryantjt's Avatar
My Tusk barsguards with expansion type hardware and it wouldn't fit inside my Tusk bars, then I looked again and they were just rubber sleeves over a knurled steel expansion nut.
Old Apr 5, 2007 | 07:22 PM
cwgoff's Avatar
I was under the impression that you only used the rubber sleeve if you were using steel bars. I know on my Moose handguards (which I used with MSR Dominator bars and now Tusk bars) I do not use the rubber sleeves. My Moose kit came with them included, but I discarded them when I screwed up my stock steel bars.
Old Apr 6, 2007 | 05:43 AM
motoguy128's Avatar
I believe I had to choose which mounting kit. I ordered my handguards with my pro taper bars so it wasn't a problem.
Old Apr 6, 2007 | 04:03 PM
double d6's Avatar
Yeah I threw away my aluminum ones when I installed the steel bars............Figures now I need them.
Made a stop to home depot, bought two1/4" nuts and bolts with some plastic tubing. I made my own bar end inserts andthey appear to hold on pretty darn good.Actually line up better than what the manufacturer supplied.
Dave
Old Apr 20, 2008 | 02:06 PM
nosneb69's Avatar
morning, I treid to fit my cycra probend to my pro taper contour bar and the U brackets don't seem to work...? I ordered the U clamps for the protaper bars but the fit does not seem to be good......baffled I am..? anybody got an Idea?
many thanks
Old Apr 20, 2008 | 02:19 PM
WestOzKLX's Avatar
Get some of these.
Or the Pro Taper kit.
See HERE for fitting list.
I'm sure it's the BTC ANS kit.
GaryC
Jul 12, 2010 10:46 PM
jpaul310
May 1, 2009 07:30 PM
cliffsta
Mar 29, 2009 08:27 PM
rbarchi
Aug 9, 2008 05:40 AM
rykawasaki83
Jul 12, 2008 10:46 AM
