power outlet
was able to make room for the socket outlet mount on the handlebar...used a roadbike stem spacer (look carbon spacer) to have the socket outlet sit 1 cm higher allowing enough room for the bottom and wire to clear the fork top.....wire was completely hidden...running between the gas tank and frame...fuse located underneath the seat...clean!
