ok next improvment on my new baby h4 bulb ?
Old Oct 27, 2014 | 06:12 PM
ol'klx-er's Avatar
Thanks. & ordered.
Old Oct 27, 2014 | 09:31 PM
rgmr250's Avatar
Thanks. & ordered.
On my KLX, I made a sheet metal replacement for the 'number plate' at the front - that way I had a vertical section to mount the lights. I did this because the number plate is sloped. After making it, I realized that I could just cut a piece of thick fuel line hose at an angle and put half of it in front and half behind, which made the light come out of the number plate at an angle, so even though the number plate isn't vertical, I could have the lights vertical. So, on my son's KLX, I just drilled holes in his number plate and put the lights through the holes, with my angled rubber hose pieces on either side, so angle the lights so they weren't pointing up in the air.
In retrospect, I probably would have done the same to my KLX as my son's. The only benefit of what I did is that I don't have holes drilled in my number plate if I ever decided I don't want the lights there, I can just take of the sheet metal number plate and put the original back on.
Old Oct 27, 2014 | 11:01 PM
ol'klx-er's Avatar
Great tips. Thanks for passing that on.
Old Oct 28, 2014 | 03:51 PM
azdeuce's Avatar
Default piaa
Im running the Piaa 80/100
Its been a year and no Issues..
Says same wattage
Old Mar 27, 2015 | 11:18 AM
taxonomy's Avatar
Originally Posted by RobG
I just put a Cyclops H4 LED in my KLX... works awesome. It's 30 watts low and 35 watts high, rated at 3600 lumens.
I also run a pair of inexpensive eBay LED aux lights along with it (10 watts each), so nighttime visibility isn't an issue at all.
Rob
3600 Lumen LED Headlight bulb for Dirtbikes/Dual Sports
Is anyone else running one of these? It looks great, more light and less power. Does anyone know if our headlight is AC or DC?
Old Mar 27, 2015 | 02:02 PM
anciano's Avatar
Why not install some low-draw LED auxiliary lights for the occasions when you really need more light? I put a pair something like this on my V-Strom:
exLED High Brightness 10W 12V 850lm 6000K LED White Light Motorcycle Headlamp - Black - Free Shipping - DealExtreme
Same company, but different style.
I would not trust either the headlight housing or wiring with a 100W bulb. But maybe I'm overly cautious.
ghost_dog
Jun 21, 2007 03:24 AM
GC
Ninja 500R
13
Mar 6, 2007 06:43 AM
EMS_0525
Jan 4, 2007 10:12 PM
aszrael1266
Oct 23, 2006 08:16 AM
kwninja88
Dec 22, 2005 09:30 AM
