Sylvania Silverstar bulb replacements
Old Dec 20, 2005 | 07:55 AM
kwninja88's Avatar
Default Sylvania Silverstar bulb replacements
For those of you who have replaced their stock headlight with silverstar, preferably with an H4, I have a question:
Did you notice a distinct, unusual odor shortly after warming up the engine? (about 1-2 min)
I just installed one on my '05 250 and as soon as I was getting ready to take off I noticed a smell and decided to not risk a wire meltdown and cut ignition. I quickly pulled the connector off and felt to see if it was hot and it was actually not even warm at all.
I am hoping that it is just some kind of coating placed on the connectors that was burning off, but I certainly don't want to risk anything that I just don't know about.
Any info on this would be greatly appreciated!
Old Dec 20, 2005 | 04:24 PM
frank80's Avatar
Default RE: Sylvania Silverstar bulb replacements
There shouldn't be a smell related to the headlight bulb, but it could be the rubber grommet that covers the bulb after it is inserted in the housing. If it touches the contacts, it could burn; check to see if it or anything else is melted. Other than that, look for leaks (oil, radiator) and especially chain lube on the muffler.
Old Dec 21, 2005 | 12:49 AM
kwninja88's Avatar
The grommet is most likely the culprit. The smell did resemble a "chemicalish" smell, possibly rubber. I sure hope it won't blow, but considering your post about it in the H4 thread, I can only assume it is still working properly for you?
Old Dec 21, 2005 | 12:53 AM
kwninja88's Avatar
Problem solved I believe. You were correct about the rubber grommet even though there was no visible heat damage to them. The male connector was not hot nor was the female end after a near warmup and cold idle and no smell was present. thanks for the suggestion.
Old Dec 21, 2005 | 04:41 PM
frank80's Avatar
Glad I could help. I still have the silverstar in my 250 and its working fine. My only real gripe is that "I" seem to see the road more clearly with the yellow light as opposed to white light. Of course I live in florida, where alot of the streets are faded asphalt or concrete, so its hard to tell what's ahead of you anyway. It does seem to shoot further out than the stock bulb, but I may have accidently adjusted the headlight level when I low-sided last summer .
Old Dec 22, 2005 | 09:30 AM
kwninja88's Avatar
I do love how it shoots farther. Keeps me from running over the metal junk that people throw or drop on the roads around here! Though I haven't had the opportunity to see the road at night yet, I don't think I'll have too much trouble (Never know though).
dan888
Apr 13, 2016 11:35 PM
Brieninsac
Sep 21, 2012 12:59 AM
Thop
Mar 29, 2011 01:44 AM
horizonod
Dec 29, 2008 09:21 PM
internetcancer
Ninja 250R
May 8, 2008 02:00 PM
