oil supply tube, front brake hose
Hello fellow KLX 250 owners,
Has anyone noticed how close the oil supply tube is to the header pipe? This tube apparently supplies oil to the camshafts and trans via a little steel tube that is about a quarter inch away from the header pipe. I will try to move the header pipe up a bit, but I'm not holding great hopes for this. I also noticed that the front brake hose was banging/rubbing against the crash-guards on the left side, maybe a braided line and a different brake hose guide is in order here.
Regards,
Will
2009 KLX250SF
Regards,
Will
2009 KLX250SF
I noticed the proximity of the oil feed when I put an aftermarket head pipe on my bike. I flexed it just a bit and, in spite of not liking it, I will probably wrap the pipe for a bit of insulation.
Thanks KLX678, I was thinking the same thing, maybe tweek the oil line slightly, possibly some heat-wrap. I loosened the headpipe clamp at the cylinder head, hoping to be able to get another quarter inch clearance, no luck with that,.
Will
Will
I run an aftermarket header, so I'll just jam a bit of fiberglass wrap between the oil line.
Richard Avatar
Z1000
Jul 8, 2014 08:31 AM
