oil supply tube, front brake hose
Old May 2, 2024 | 01:56 AM
wjstengerjr's Avatar
Default oil supply tube, front brake hose
Hello fellow KLX 250 owners,
Has anyone noticed how close the oil supply tube is to the header pipe? This tube apparently supplies oil to the camshafts and trans via a little steel tube that is about a quarter inch away from the header pipe. I will try to move the header pipe up a bit, but I'm not holding great hopes for this. I also noticed that the front brake hose was banging/rubbing against the crash-guards on the left side, maybe a braided line and a different brake hose guide is in order here.
Regards,
Will
2009 KLX250SF
Old May 2, 2024 | 12:07 PM
I noticed the proximity of the oil feed when I put an aftermarket head pipe on my bike. I flexed it just a bit and, in spite of not liking it, I will probably wrap the pipe for a bit of insulation.
Old May 3, 2024 | 12:41 AM
Thanks KLX678, I was thinking the same thing, maybe tweek the oil line slightly, possibly some heat-wrap. I loosened the headpipe clamp at the cylinder head, hoping to be able to get another quarter inch clearance, no luck with that,.
Will
Old May 3, 2024 | 03:54 PM
tooter's Avatar
That's a good idea. I run an aftermarket header, so I'll just jam a bit of fiberglass wrap between the oil line.
Richard Avatar
Z1000
Jul 8, 2014 08:31 AM
Richard Avatar
Nov 17, 2013 10:37 PM
cegusman
Jun 15, 2011 06:49 PM
Guido
Dec 22, 2009 11:53 PM
poolhustler21
Sep 27, 2005 12:38 AM
