Oil drain plug width
I'm rebuilding my KLX after a balance shaft bearing failure, one thing I noticed is the oil pump is damaged due to the metal particles that fitted through the brass gauze being pump though the motor, a magnetic sump plug will not stop all the particles but will give you a good indication that something is not right at oil change time, the magnet in the filter will catch the metal that the filter would have caught anyway.
Think about it:
I can't imagine the drain plug magnets do anything at all, except for catching a few suspended particles when the bike is PARKED. With the engine running, only a tiny fraction of the oil will be passing anywhere near the oil plug. The engine would have to be stopped for anything to settle close enough to the drain plug for the magnet to attract the particles, and even then, any particles beyond the field of the magnet will remain in the oil.
If your oil pump was damaged by metal particles as you say it was, then your oil filter was NOT doing its job! I'm guessing it was probably a K&N or some other non-paper (i.e. metal mesh "reusable") oil filter.
