oil change
Old 05-31-2015, 12:37 AM
Tin's Avatar
Tin
Tin is offline
Default oil change
Just a quick one about the oil change for a 09 klx250s just done oil change couldn't find clutch or transmission to change my question is does It all use the same fluid or is there something I'm missing if so do I need a special oil that does all 3 or just normal engine oil thanks for any help
Old 05-31-2015, 02:46 AM
MaximusPrime's Avatar
The same normal oil lubricates it all.
Old 05-31-2015, 03:30 AM
ol'klx-er's Avatar
Normal oil = motorcycle rated oil in this case. NOT car oil.
Old 05-31-2015, 04:52 AM
Tin's Avatar
Tin
Tin is offline
Thanks for that. so only one oil change near the brake pedal and that does all 3 so probably change about every 1000 km if lubricating everything
Old 05-31-2015, 12:47 PM
marcham's Avatar
Why change it so often? Unlike a 4 stroke dirtbike, there's enough oil in the case to avoid having to change it every 15 hrs. It's not like your bouncing off the rev limiter non stop with a mud encrusted rad.
Old 05-31-2015, 05:18 PM
Nah, 3000-5000 km is more like it. I do 3000-5000 miles on my bikes, one being a KLX650 with about the same amount of oil in it. 47,000 miles and going strong.
Old 05-31-2015, 07:03 PM
ol'klx-er's Avatar
This post mentions what the oil's label should show:
https://www.kawasakiforums.com/forum...36/#post520941
yjsjin
07-12-2009 12:28 AM
cwgoff
01-30-2007 09:23 PM
slablocal
07-08-2006 08:21 AM
Red636guy
04-24-2006 09:50 AM
Quick Reply: oil change
