Noise after engine warmed up
If it does it when sitting still, hold the rpm at a range where it is made and listen around the engine to try to locate the noise. If it is only making noise when rolling look at the drive line.
It's from the camshafts area and more towards the intake camshaft. The only thing i can see, is the timing chain guide (intake side) touches the inside of the cyl head on the right side. I am wondering if the noise of the chain, rubbing against the guide, is being transmiited to the cyl head and the cyl head is acting like a 'sounding board'
Why are you so certain it isn't the tensioner? After all, it is in the back of the cylinder head on the right side. Does the bike have the OEM tensioner? If it does and you live in the U.S. about the least invasive and least expensive thing to try is the cam chain tensioner. If you have a manual tensioner you may want to see if it is too tight. If you have the manual tensioner this link should take you to a tensioner instruction sheet. click here If the link doesn't work let me know.
Manual tensioner or original auto tensioner, the noise is the same. I have had KLX250's for 12 years now and worked / serviced many others but never experienced a noise like this.It's not a worrying noise but it certainly gets on my nerves
. Next step, modify the rear cam chain guide so it doesn't touch the cyl head. I'll update later.
So He-Man I may be...
I loosened the tensioner all the way (bolt was wiggly) and then tightened until it just hit the guide (not wiggly). I backed it out a smidgen and started it...low and behold I heard (for the first time ever) the ticking every one speaks of. I turned it (very slightly) to mask the ticking a touch after the bike warmed up a bit.
After a test ride, the whirring has not returned (as with these things, I will add 'yet'). If this result remains, then it can be assumed that my auto tensioner initially failed by over-tightening, causing the whirring that I assumed was a loose chain...and the return of the symptoms (which began after the weather started warming back up)was caused by my inability to rationalize what 'finger tight' means. We shall see. I can't thank you enough for the help!
. Next step, modify the rear cam chain guide so it doesn't touch the cyl head. I'll update later.Thread
Israel-klx250s
Mar 4, 2012 08:33 AM
FlyingSquirrel
Apr 3, 2008 01:56 PM
