Newbie from UK wanting few mod tips etc......
Old Dec 15, 2015 | 07:46 PM
spadey99's Avatar
Default Newbie from UK wanting few mod tips etc......
Hi guys
getting my 2015 KLX this week, wanted to know whats worth doing??
Ordered a 02 eliminator........ and heard about the clutch mod?????
Also heard Q4 exhausts seem to be the best option.... full system or just end can???
Any pics tips especially for the clutch mod and what wire to use and where to put it with pics to help a newbie and where to hide it when done is really appreciated....
Also the snorkel removal?? easy??? any pics????? change air filter or not????
Thanks in advance.....
Steve
Old Dec 15, 2015 | 07:49 PM
spadey99's Avatar
oh and best place to purchase a Q4 exhaust in UK
Old Dec 15, 2015 | 10:46 PM
MaximusPrime's Avatar
Old Dec 16, 2015 | 12:09 AM
Klxster's Avatar
Well, if you do a full FMF exhaust, the MCM (Marcelino Cam Mod) , remove and cap off the air injection system, pull the airbox lid off, AND fuel it correctly - you'll have (around) 25hp with a power band that stretches to redline.. You'll love it !!
Old Dec 16, 2015 | 09:30 AM
spadey99's Avatar
thanks guys some great info.... wow what a difference a paper clip makes......... what about o2 eliminator??? only a few quid......
Old Dec 16, 2015 | 09:09 PM
Welcome spadey, one thing to note is that the bikes sold in different countries actually have some differences. I believe all KLX sold in the US still have carburetors, and do not have the O2 sensor. There are some guys on here that will have info on the FI bikes .
Dan
Old Dec 17, 2015 | 09:36 AM
zl PINHEAD lz's Avatar
Old Dec 17, 2015 | 05:01 PM
reinigef's Avatar
Don't forget to loosen your clutch and brake lever perches just enough so they will move when you pound on them with the palm of your hand. May save lever breakage as they will rotate on impact. Then you can smack them back into position...
Old Dec 20, 2015 | 10:23 PM
willb's Avatar
From: Cheshire, in between the Welsh hilly bits and the Peak district hilly bits - just about in the North
Clutch mod is dead easy to do - slide off the clutch switch just under where the clutch cable leaves the clutch lever, short across the two outer holes on the removed plug (now hanging off the end of your pice of wire) tape up neatly with a bit of tape. Job done no more restriction on revs at high engine speeds in gears 4,5 & 6. Did mine 8,000 miles ago no problems - except it will start in gear unless footstand is down.
If you intend going on the muddy stuff :- decent tyres (of course what constitutes decent tyres is a never ending discussion) / take footpeg rubbers off - they just unbolt, stop your feet sliding off the pegs when wet / consider a 13 tooth front sprocket for better low speed gearing / hand guards - keep your fingers a bit warmer and help if you have a little tipple off / change mirrors to foldy down ones or just take them off and look over your shoulder.
Join the TRF and they will take you out on decent lanes.
Old Dec 21, 2015 | 07:55 PM
spadey99's Avatar
thanks Will B great info....
B_Known
Sep 17, 2014 07:05 PM
brcook
KX65
Jan 17, 2013 01:47 AM
Flood_33
Mar 23, 2008 03:57 PM
MIPLAYSTATION
Dec 5, 2006 08:50 AM
tremor38
Nov 28, 2006 02:19 PM
