New KLX300 - cam specs change at all?
Old Apr 23, 2024 | 04:31 AM
tsc's Avatar
tsc
klx300 dual sport (2020+) and klx250s camshafts are the same. klx300r (2020+) camshafts are different. Also klx300r camshafts are the same as ninja z250sl (250cc engine, see attached diagram) which produce 28hp@9700 & 22.5Nm@8200. Sprockets on klx300r and z250sl also same. And these are different (different part numbers) from kls250s and klx300 dual sport. Did anyone figured our if sprockets are actually different (different cam timing?)?
Old May 29, 2024 | 01:44 AM
tsc's Avatar
tsc
According to Keng Engine gears are same!
Old Jun 7, 2024 | 08:07 AM
tsc's Avatar
tsc
For those who follows:
  1. All klx250 (including klx250s, klx250r, klx250E, klx250D, klx250A) have same camshafts. These are also same with 2021+ klx300 dual sport and old (prior to 2007) klx300R. All these have part numbers which cross match. You can find more details in this thread. I've checked service manuals for klx250r, klx250e, klx250d, klx300 and modern klx250(s) EFI. These cams have same duration timing and lift:
    1. Exhaust BBDC 61° - ATDC 19°, , duration 260°
    2. Inlet BTDC 22° - ABDC 62° , duration 264°
    3. Intake Lift 36.246 ∼ 36.354 mm, Exhaust lift 36.246 ∼ 36.354
    4. So exhaust LCA 111° BTDC, intake LCA 110° ATDC and LSA = (111 + 110) / 2 = 110.5°
  2. New 2020+ KLX300R camshafts and/or cam gears are different from above. 2020+ klx300R camshafts and gears are identical to Ninja Z250SL (same part numbers). I could not find klx300r service manual, but I found z250sl service manual. Which states following timing and lift:
    1. Exhaust BBDC 63° - ATDC 21°, duration 264°
    2. Inlet BTDC 20° - ABDC 64° , duration 264°
    3. Intake Lift 35.743 ~ 35.857 mm, Exhaust lift 35.743 ~ 35.857
    4. So exhaust LCA 111° BTDC, intake LCA 112° ATDC and LSA = (111 + 112) / 2 = 111.5°
Lower lift is especially surprising. Wider LSA make sense for z250sl which makes top power at 9700rpm, but not so much for klx300r which should have bottom torque.
Also since timings vary very slightly from klx250 I would suspect cam gears are same as klx250, but only camshafts are slightly different.
Old Jun 7, 2024 | 02:55 PM
tooter's Avatar
This is fascinating information. Thanks for compiling it.
For reference, I dyno tested my 2021 KLX300SM
HP 25.0 @ 9,100 RPM
TQ 16.5 @ 7,600 RPM
This was bone stock with a slip on exhaust as the only mod.
Old Dec 24, 2024 | 09:36 AM
tsc's Avatar
tsc
Camshafts article with all the KLX300R(2020+) and KLX250/300 specs - https://planetklx2.netlify.app/docs/engine/camshafts/
@RaceGass you've been correct - Keng cams are not KLX300R cams. Their base (how they are attached to timing gear) is the same as in KLX250 and different from KLX300R.
And detailed video comparison:
Old Dec 25, 2024 | 01:22 AM
RaceGass's Avatar
@RaceGass you've been correct - Keng cams are not KLX300R cams. Their base (how they are attached to timing gear is the same in KLX250 and different from KLX300R)
And video comparison:
https://youtu.be/FkBhQYaSjA4
Thanks for clearing up the cam manufacturer question. The cam gears being different helps make the decision to go with Kengs cams an easy one, price wise also.
Old Mar 18, 2025 | 06:54 AM
tsc's Avatar
tsc
Update - 2020+ klx300, 2020+ klx300R and z250sl cams are the same (the only difference is KACR in klx300. why??) -
Evostick
Nov 20, 2017 04:33 PM
RaceGass
Jul 8, 2011 08:55 AM
SlapDrum
Mar 31, 2009 07:30 PM
Archer
Nov 16, 2007 11:39 PM
GreenKLX
KLX300R
Feb 23, 2007 08:57 PM
