New KLX250 for me!
Old Aug 30, 2012 | 04:16 PM
System6's Avatar
Nice bike.
Welcome to the forum.
Enjoy.
Old Aug 30, 2012 | 05:13 PM
WHIP-N-DIP's Avatar
Originally Posted by Lotrat
There is a grounding mod to fix the stumble at 6500 rpm which I'm about to do. I'd make sure its not your carb causing it first. My bike has always had it, just getting annoying a year later.
you haven't regrounded the wire yet? it's really easy, i havnet hiccuped on this new 09 i got... yet
Old Aug 30, 2012 | 05:47 PM
ahnh666's Avatar
heart is now set on the 2013 ktm 350 exc-f....it's exactly what i'm looking in terms of lightweight 242 lbs, 40+ hp at 10,000 to 11,000 rpm and 23+ lbs. torque at 8,000 rpm....
Old Aug 30, 2012 | 05:59 PM
Brieninsac's Avatar
That's a sweet looking bike!
Old Aug 30, 2012 | 06:04 PM
Lotrat's Avatar
Yeah, not that into it.
Change the spark plug and spark plug connector. x •
Change the piston. x •
Check/measure the cylinder. x •
Check the cylinder head. x •
Change the valves, valve springs and valve spring seats. x •
Check the camshaft and cam lever. x •
Change the connecting rod, conrod bearing and crank pin. x •
Check the transmission and shift mechanism. x •
Check the oil pressure regulator valve. x •
Change the suction pump. x •
Check the pressure pump and lubrication system. x •
Replace the timing chain. x •
Check the timing assembly. x •
Change all engine bearings. x •
S105A: Every 105 operating hours/every 50 operating hours when used for motorsports
Old Aug 30, 2012 | 06:05 PM
Lotrat's Avatar
Yeah, I know. I'm just lazy.... but it seems to be annoying me more these days.
Old Aug 30, 2012 | 06:45 PM
ahnh666's Avatar
oops..posted on the wrong thread..hahhaa
Old Aug 30, 2012 | 09:48 PM
rgoers's Avatar
Awesome looking bike! It's got everything:
good looks,
high price,
frequent maintenence...
yeah, no thanks!
Old Aug 31, 2012 | 12:22 AM
DustyCowboy's Avatar
Thank you for the help guys! ;-)
I've already put a new plug in when I did the oil change.
I don't know how I missed it when I did my research concerning the hiccup, but here is the ground mod done on my bike 30 minutes ago.
There's still a lot of parts to be bought for the bike, including a skid plate, some hand guards, a bigger tank and a rear rack just to name a few.
I'll try the bike tomorrow if I can find some time and report back to give you updates about the ground mod.
Thanks again ;-)
Old Aug 31, 2012 | 04:19 AM
Lotrat's Avatar
Originally Posted by DustyCowboy
...here is the ground mod done on my bike 30 minutes ago.
OK OK, you guys shamed me into doing the ground mod. Seems to have fixed it, but I just took a short ride. I'll know this weekend for sure. Thanks for the push.
