needle clip setting
Old 07-04-2011, 04:45 PM
cegusman's Avatar
Default needle clip setting
Posting from my phone which won't let me search the forums.
What does moving the clip up do vers moving it down. Looking to see which way will add more fuel.
Old 07-04-2011, 04:53 PM
2veedubs's Avatar
Putting the clip lower will allow more fuel as it will raise the needle
ns503's Avatar
Clip up (needle down - in the hole more) means leaner, clip down (needle up - out of the hole more) means richer.
Old 07-04-2011, 05:02 PM
cegusman's Avatar
Thanks. Just what I needed.
Old 07-04-2011, 05:05 PM
Marcelino's Avatar
Your main jet alone controls the fuel delivery from 75% to 100% , you should try various sizes to see what size works best for you .
From 25% to 75% the mixture is controlled by the needle in conjunction with the main jet that you had previously chosen . Lowering the needle leans the mixture , raising the needle enriches the mixture . If you later need to change the main jet size you will need to do the needle again . To answer your question the needle acts like a cork for the main jet , it lets a little or a little more gas pass by .
From 0 to 25% you depend on the pilot jet , this mixture is adjutable with the idle mixture screw and the tool ( if you have one ) .
stro
04-12-2012 10:05 PM
redixson
02-18-2009 02:44 AM
cwgoff
12-20-2006 07:35 PM
xmxracer
01-05-2006 08:02 AM
Bluebeast
10-26-2005 07:14 PM
Quick Reply: needle clip setting
