needle clip setting
needle clip setting
Posting from my phone which won't let me search the forums.
What does moving the clip up do vers moving it down. Looking to see which way will add more fuel.
Your main jet alone controls the fuel delivery from 75% to 100% , you should try various sizes to see what size works best for you .
From 25% to 75% the mixture is controlled by the needle in conjunction with the main jet that you had previously chosen . Lowering the needle leans the mixture , raising the needle enriches the mixture . If you later need to change the main jet size you will need to do the needle again . To answer your question the needle acts like a cork for the main jet , it lets a little or a little more gas pass by .
From 0 to 25% you depend on the pilot jet , this mixture is adjutable with the idle mixture screw and the tool ( if you have one ) .
