Need simple step by step instructions on removing front wheel
Old 10-05-2011, 01:38 PM
mtbjunkie09's Avatar
Default Need simple step by step instructions on removing front wheel
Don't want to screw anything up from the beginning, so can someone give some step by step instructions. I searched on You tube, but the 2006 KLX I have looks different than anything I found
Thanks
Old 10-05-2011, 02:29 PM
CousinLarry's Avatar
There's four 10mm bolts holding that plate that keeps the axle tight. Loosen those.
Then remove the axle- I wanna say it's 14mm but could be wrong.
Done. If it takes you more than two minutes, you're doing something wrong.
Be careful when you tighten those four nuts again - they will snap the studs easily if you over tighten them.
Good luck, this is about the easiest thing you can do on the bike. If you can breath, you can do this..
Old 10-05-2011, 02:30 PM
Figured it out pretty easily, but let me know if there is anything I should look for when putting it back on after I get the tire changed.
Thanks again
Old 10-05-2011, 03:59 PM
Just make sure your brake pads are spread and the disc goes in between them.
Make sure the spacer is on the left side. Make sure the speedo sensor gear/assembly is on correct, there is a knotch that fits between two knotches on the fork.
That's about it..
Old 10-05-2011, 04:49 PM
Thanks guys...really helped.
Old 10-05-2011, 04:52 PM
klxrida's Avatar
Here's a good article on the 'importance' of front wheel installation MTBJunkie if you want to get all technical. I think this is what you were looking for...
Installing a Front Wheel on a Dirt Bike Should be Done Like This
Old 10-06-2011, 09:31 AM
Just keep taking nuts and bolts off untill the wheel falls off....
10thmountainman
03-26-2013 05:31 PM
Mcnutts
12-21-2012 05:33 PM
snowburt80
Ninja 250R
02-24-2008 10:59 PM
pitbull419
09-23-2007 08:13 PM
ZX_9r
01-27-2006 08:26 PM
Quick Reply: Need simple step by step instructions on removing front wheel
