step by step carb removal and rejet
Old Mar 23, 2013 | 08:03 PM
10thmountainman's Avatar
Default step by step carb removal and rejet
Does this exist somewhere? I would like to see exactly how it done so when my parts come in I know what to do. Would really like to see pics and descriptions.
Old Mar 23, 2013 | 09:03 PM
This one's not bad. A few type-Os to be careful of.
Go to this page https://www.kawasakiforums.com/forum...q-links-30733/
where you'll find lots of good stuff.
See Post #20, and look for the HMF Carb removal instructions
Old Mar 24, 2013 | 09:31 AM
Thank you!
Old Mar 26, 2013 | 05:31 PM
BigSky KLX's Avatar
Honestly, the few write-ups that are around help a little bit and are okay, but it really isn't that hard to begin with.
Take the seat, shrouds and tank off. Unplug the wiring harness to the carb, unhook the throttle cables, undo the two rubber boot clamps and out it comes through the top of the frame. I guess there are a couple of vacuum lines ( which I have long since plugged ) you might have to unhook. It is a very straight forward job. Meaning you can see what needs to be done to get it out.
Once out, the top cover on the carb houses your needle and spring, and the bottom cover houses your jets and fuel mixture screw.
Actually getting the carb back in was the hardest part for me. The tight clearances and rubber boots tend to get in the way. Just take your time, it might take a couple of attempts, and it will go back together.
After pulling mine a few times, I can go from completely assembled to the carb sitting on my workbench in 15 minutes.
Mcnutts
Dec 21, 2012 05:33 PM
mtbjunkie09
Oct 6, 2011 09:31 AM
pitbull419
Sep 23, 2007 08:13 PM
Jun 18, 2006 05:58 AM
ZX_9r
Jan 27, 2006 08:26 PM
