Need instructions to remove rear wheel
1. Remove the rear brake caliper.
2. Loosen the axle nut, and kick the rear tire forward so you can get the chain off the sprocket.
3. Remove the wheel alignment screw & caps at the end of each side of the control arm. (These are the screws that stick out of the control arm ends.
4. Pull off the wheel.
That's it.
Remember, you will need to re-align the wheel once you reinstall it.
That's it.
mtbjunkie09
Oct 6, 2011 09:31 AM
BIG V
May 28, 2007 05:04 AM
