Need advice on buying a slip-on exhaust
Old Feb 22, 2012 | 03:08 AM
2veedubs's Avatar
Good choice!
Old Feb 22, 2012 | 03:13 AM
2007KLX250S's Avatar
I'm in the market for a slip on as well and found some good deals while looking around on Amazon.com
However, some of them said they would fit a klx between 06-10. Is the 06-07 really interchangeable with 09-10?
Old Feb 23, 2012 | 06:09 PM
Brieninsac's Avatar
I know what I'm doing after work today.
Old Feb 23, 2012 | 06:15 PM
ahnh666's Avatar
socket wrench set and allen key....little wd40 if the bolts are stuck...you have a new bike, so it should come right out...just make sure you grease the threads when you put it back on...or, you'll have stuck bolts again when you try to take it off.....bolts on exhaust get hot and cold, so it can get stuck later on down the road...
Old Feb 23, 2012 | 06:26 PM
2veedubs's Avatar
Dont forget to bend the passenger peg gaurd. Otherwise it just wont line up quite right, and you will be like WTF? A wooden hammer handle or a pipe wrapped in a rag or tape works good to bend it out away from the bike without scratching the frame. Your going to love the sound.
Old Feb 23, 2012 | 09:27 PM
Brieninsac's Avatar
Overall, a pretty smooth install. The only sticking point was getting it on the rear bolt and middle hole lined up. But after playing with it and pivoting it out I got them both to seed fine. I love the sound! I'm glad it's not significantly louder then the stock pipe. My neighbors will appreciate that.
Sindre Bjerkeng Scherjon
Feb 13, 2013 10:23 PM
rkutzner
KX125
Feb 26, 2008 09:04 PM
praetorian
Ninja 500R
26
Nov 23, 2007 01:48 AM
PittSAMmy
Dec 5, 2006 09:58 PM
ninjawantabe
Ninja 650R
Mar 25, 2006 02:59 AM
