More mods completed
Over the last couple days, I've added Pro Taper RM Low bars to my 09SF. I had to get the Pro Taper universal adapter also. It was an easy add on. The bars are a little longer than stock, so when I put the throttle back together the RPM's would increase when I turned full left. I had to reroute the cables and so far, no problems. I put some Zeta bar ends on. I'd like the get the hand guards that are also turn signals, but that's for later. The final thing I did tonight was to install a Streble Nautilus electronic air horn. 138db's of locomotive sound
. I didn't try it as it was too late, but I'll be testing in the morning. I got the horn from ebay and it had the wiring harness already built up. The install was pretty simple.
