More of a crankcase "venting" question than a "mod"?
Old Jan 7, 2024 | 12:47 AM
RECON250s's Avatar
Default More of a crankcase "venting" question than a "mod"?
It looked like someone had 'tinkered' with the CC vent vac module thing/09 KLX250 (just behind the radiator with large hose that runs to top of airbox and small vac hose to carb). So, I removed the vacuum module, capped off the vacuum line at the carb, and just ran that cc vent hose straight to the top of the air box. Make sense?
So in short, I have the bottom cc hose going from engine straight to bottom/airbox, and the top hose going from top/front of motor straight of top of airbox. Nothing in between, both hoses just straight to appropriate airbox inlets.
Does anyone see an issue with this? So, (as far as I know) vacuum from the carb/acceleration will draw cc air in all the time keeping negative air pressure in the cc with no ill effects (other than that air going into carb which doesnt bother me).
Also, what is the path of the cc vent/air flow?
Thoughts? Thanks in advance
Old Jan 7, 2024 | 01:21 PM
If you're leaving the stuff there you may as well hook up the intake vacuum and let it work. I would venture to say the valve now isn't working with no air being drawn in. Removing it only saves the weight of the parts, nothing else. There is no effect on performance by disconnecting or removing the PAIR valve. It just means a bit more pollution when it doesn't work.
I only took the system off my bike when I changed carburetors to one without the vacuum fitting. Then I blocked off the head opening. If the carb had the fitting I'd have left it on. It was a bit of a pain in the butt to plug the air box, finding a cap for the hole, and to put a block plate on the head.
Old Jan 7, 2024 | 01:35 PM
RECON250s's Avatar
Thanks... perhaps I should have clarified, I removed the PAIR valve altogether and just installed an open elbow in it's place/where the valve was... then capped off the vac line at the carb. So in effect, I now have two (upper and lower) cc vent lines completely open attached where they were stock (both engine to airbox hoses)... just no inline valve. So I guess my question is, shouldn't the cc still be getting adequate venting just from the vacuum from the airbox/intake?
That's the way it works when the Rottweiler air intake is installed on the 690... the cc vent hoses both come to a collection/catch can type box, the the breather line either go to clean side of air intake or runs up higher by itself with a K&N type mini-filter.
Thanks for the input
Old Jan 8, 2024 | 08:32 PM
The crank case breather hose simply goes from the crank case to the air box. The PAIR has nothing to do with the crank case ventilation and is not connected to the crank case unless someone really screwed with those hoses. The PAIR hoses and valve are only a source for air to suck into the exhaust to burn unburned fuel mix.
The thing that makes the most sense is to block off all three ports related to the PAIR system. Cap the opening on the air box where the line comes out to the valve. Cap the opening on the reed block on the head. Block the vacuum port. That or put the system back together right. The tube from the top port in the air box goes to the side port on the PAIR valve, then a tube on the bottom of the valve goes to the reed valve in the head. Then there is the vacuum hose.
See the set up below.
Old Jan 9, 2024 | 02:40 AM
RECON250s's Avatar
Edited to add: I see where i was mistaken re: the cc vent vs PAIR system. Thank you
Old Jan 10, 2024 | 11:04 AM
Glad I could help. It was getting me a bit confused along the way. I will also say I have had stuff like that screw me around as well. Not like I'm some expert by any stretch.
I just noticed the Yamaha... had to look that one up. Never have ridden a personal watercraft. We carried Kaw back in the 80s for a bit. Didn't sell well where we were, in the middle of town, no lake too close and those that were around had horsepower limits that kept them off most lakes. I wish I'd had the opportunity to try one out. Like motorcycling on water I'd think.
Old Jan 10, 2024 | 11:24 AM
RECON250s's Avatar
Yes sir, thanks again. You got my head in the right place. I've swapped out motors (chevy into CJ5/7s) since I was 16, and do most of my own work... but must have lost my edge on this new KLX250 learning process. I just capped it (PAIR sys) off and left the bottom cc breather hose going to air box/cc. The popping on decel stopped immediately.
I'll post a pic of my stock muffler mod soon (simple but works). Next mission is to take the horrid rattle out of the aluminum skid plate!
On the PWCs... I was slow coming around to those about 5 hears ago (had a few), even having grown up on Pensacola Beach/Gulf Shores. Wife and I have had everything from skiffs, to larger Grady White walk-around cuddys, Yamaha Jet Boats, and now back to the Waverunner. Mid-55s, empty nesters... and turns out I married an 'explorer'. Correct, Waverunner is like a bike on the water. We took it up to Muscle Shoals to explore the TN River, and we explore a lot don here on the delta/gulf. We love it... and don't have to entertain on it, LOL!
So I'm just getting into the dual sport riding after 25 years on the road... don't even have a road bike anymore. Reach out anytime you happen to be in my area and you can take the PWC and go have a blast... I'll leave it in the driveway with the ignition code.
Thanks for the help...
Old Jan 10, 2024 | 01:20 PM
Tacoma660's Avatar
I made my own skid plate outta think plastic, doesn’t look the best but for not hopping logs it does the trick
cleandirt
Feb 13, 2019 06:20 PM
jabara572
Jun 13, 2017 02:31 AM
alexgg
Jan 13, 2012 03:39 AM
Feral Donkey
May 3, 2010 03:47 AM
WestOzKLX
Apr 27, 2008 03:23 AM
