Larger fuel tank?
Old Jan 12, 2007 | 03:49 PM
  #51
DJFields's Avatar
Default RE: Larger fuel tank?
I agree with Deej, a bigger tank but no mods to the bike. I'll buy one!!!
Old Jan 14, 2007 | 05:31 AM
  #52
mmatz's Avatar
ORIGINAL: DJFields
Ok, lets keep the emails going to Clarke mfg. and see if they take the positive input. This a great opportunity for forum members to express thier design wishes. Do you want wings? Or do you prefer the IMS style? Personally, I would like to keep things asclose to stock looking as possible but with as much fuel on board as is reasonable. Anyway, I just sent another email to www.clarkemfg. In the meantime I willbe installing a KLX300 tank.
Hey cwgoff, didn't you put the KLX300 tank on your bike? After you get back from the TOUR and all that balmy weather any tips would be appreciated.
Old Jan 14, 2007 | 05:39 AM
  #53
jsac's Avatar
hope any1 that sends emails will include a link to this thread within them.. will give the designer(s) a better idea of what the people want.
Old Jan 14, 2007 | 08:47 AM
  #54
vurtle's Avatar
gotta keep the stock shrouds
Old Jan 14, 2007 | 08:51 AM
  #55
Yea I don't like the wings, I would rather carry a couple of 2 litre bottles for now.
Old Jan 15, 2007 | 05:59 PM
  #56
cwgoff's Avatar
ORIGINAL: mmatz
ORIGINAL: KAWASAKIspeed
mmatz i have a KLX300R. That tank is on my bike, my dad also has the KLX250S so i have resources to both. it is really simple i will try and get pictures to you.
Chris,
Thanks for theinfo and photos inthe next post. That strap is going to be on order from my local dealer tomorrow. Does your dads KLX250S have the KLX300 tank? I am curious about the radiator fans and coil placement and also of any tabs or anything that might need to be removed to get that 300 tank in there.
I have the KLX300 tank installed on my KLX250S. I re-routed the wires to give a little more space for the tank to seat. I basically copied the steps that BMWHD and Nobrakes used to install their IMS tanks. The IMS tank is a little bigger, so that extra space may have necessitated the re-routing. I have always kind of wondered if I could have gotten it to work without messing with the wiring. It's probably not a bad idea to at least try it without messing with the wiring because the wiring is the only part of the mod that is even a little bit of trouble.
Just to confirm - you are going to have to ditch the stock radiator fan. It absolutely will not work with the larger tank. The guys with the IMS tanks have wired weatherproof compter fans into the stock fan harness as a good replacement. I have the fans, but I have not installed them yet. I have been running for about a month with no fans and have had zero problems. That's not too surprising since it is winter, but I put it to the test a bit with 4 days for riding at the Tour de Apalachicola with no fans. I never even came close to needing them. With that said, though, I will be installing them for peace of mind in the next week or so.
You don't need to relocate the coil, but it is pretty close. It wouldn't hurt to put in a spacer like BMWHD did. I am not sure if Nobrakes moved his or not. I have not moved mine, but I might do that when I do the fans.
You mentioned removing tabs. I had forgotten until just this moment that I did Dremel off the two hooks that serve as guides for the wiring harnesses. Now that I remember that, it makes much of what I said earlier about maybe not needing to do the wiring a moot point. You pretty much need to do it, but it's not too bad, just meticulous and a little time-consuming. I would recommend that look back at BMWHD's writeup on his IMS install for guidance. It served me well.
Old Jan 16, 2007 | 02:42 AM
  #57
mmatz's Avatar
hey cwgoff,
Glad to here that all went well at the Tour de Apalachiacola. My KLX300 tank should be here in the next day or two so your thoughts are appreciated. I am planning on doing the tank, handle bars w/ new grips, hand guards, turn signals,and the big bore allat the same time. (Maybe the pumper too, just don't tell my wife). I am hoping to have it readyforSpring riding. (31/2' of snow right now).
Doesn't the KLX300 run with outradiator fans?Mine did come on a couple of times last summer so I'm sure I will install after market ones to to be on the safe side.And Engine Ice for coolant.
Old Jan 16, 2007 | 05:06 AM
  #58
cwgoff's Avatar
mmatz, yeah, I am pretty sure the 300 does not have a fan. The difference, I guess, comes from how the two bikes are supposed to be used. With the 250, there is the expectation that you might find yourself in stop-and-go traffic, whereas the 300 is expected to be pretty much moving the whole time it is running. Either way, you will rarely need the fan, but it is good to have it just in case.
Good luck with all of those upgrades. You will have a amazing bike in the Spring.
Regards, Chris
Old Jan 16, 2007 | 06:05 AM
  #59
mmatz's Avatar
cwgoff,
Which fans did you order?
2.6 gallons is going to be acceptable but I would still like to see what kind of offering Clarke Manufacturing can come up with. And I concur with you guys. As stock looking as possible with minimal mods.
Get some rest man!
Old Jan 16, 2007 | 10:48 AM
  #60
tremor38's Avatar
Comair-Rotron
Model#: FT12B4-E2
Part#: 039271
Size: 25.4 MM X 120 MM. (1" X 4.72")
12V DC, ball bearing, 2950 rpm, 90 CFM, 4.1 Watts, Enviroshield Type 2.
ORIGINAL: mmatz
cwgoff,
Get some rest man!
