KLX300 - "Unmuzzled" Power Charts Needed.
Old May 10, 2023 | 03:59 PM
  #151
Klxster's Avatar
Originally Posted by tooter
Trust me.
That dip in the dyno chart is from the ECU controlled secondary throttle plate. I dynoed my bike totally stock except for a slip on. The secondary throttle plate holds only half way open up to 7,000 rpms, and then the ECU only opens it above 7,000 rpms.
You misunderstand me Tooter. I was trying to point out that what you are calling a "Dip" is just one indication of a much larger problem. Your entire power curve from off idle to approx 8000 rpm is a low performance abomination - artificially created via detune programming. Correct power curve shape is shown in my posted charts above.
You stand to gain far more than removing the "dip" if you remove the secondary throttle plate and dyno tune with a PCFC - it'll be like buying a whole new bigger bike !
Old May 10, 2023 | 04:46 PM
  #152
tooter's Avatar
Thanks for your concern, but for me It's not a problem because of how I use my bike, which is daily utility transportation under 50 mph on two lane rural roads.
Old May 12, 2023 | 07:34 PM
  #153
Kris250's Avatar
So here’s my Dyno graph it made more torque then what I posted. Blue line is after fuel trims where corrected with djfc.
Old May 12, 2023 | 07:40 PM
  #154
tooter's Avatar
Your chart also demonstrates the effect on the curve of removing the secondary throttle butterfly. The "dip" is gone!
Now that I have a "baseline" (slipon only) dyno, I just scheduled another dyno test for Wednesday the 24th as I've been really curious as to the results of all of the experimental mods I did, especially the secondary butterfly removal. I'll post the results here when I have the chart.
Old May 12, 2023 | 08:50 PM
  #155
Kris250's Avatar
I can pull second gear wheelies now
Old May 15, 2023 | 10:06 AM
  #156
Nigel's Avatar
The mid-range boost is very noticeable when on the trails.
Old Jan 9, 2024 | 04:58 AM
  #157
stephenspann27's Avatar
Does anyone have a dynochart of before and after megabomb?
Old Jan 9, 2024 | 04:58 PM
  #158
pgator's Avatar
Default Map File
Originally Posted by Nigel
Update. And I will test more stuff down the road like air box lid removed.
It is still kinda cool here, 40s and 50s on the good days.
I have few hours of trail riding with the mods (really sloppy, a little technical, not hard for old guy intermediate rider). Additional mods include 14/46 sprockets, D606 rear, MT21 front, IMS pegs, zeta offset risers and Renthal bars with much less sweep. I like my new setup.
Bike is a really nice trail bike (should come this way from Kawasaki), power is way better, the added midrange is really appreciated on the trails. The power delivery is nice with the PCFC map, runs flawless so far from off idle to 9K. I don't think I ever redline it, just making noise past 9K.
Thanks KLXSTER for helping me not overthink it, glad I yanked the secondary throttle plate.
Tooter, I recommend a PCFC and I will send you my map, it works well. I added a ton of fuel to the midrange/high throttle angle and that fuel is what will help with power, but more importantly long engine life.
Could I get your map file. I have the exact same setup and I am looking for a good map file for my PCFC
Old Jan 9, 2024 | 05:08 PM
  #159
pgator's Avatar
Kris250, Could I please get your map file. I have Del slip on exhaust, OS and Pair deletes, secondary removed and my PCFC is shipped and would love to load your map on that.
Old Mar 12, 2024 | 06:06 AM
  #160
tsc's Avatar
tsc
Chart with proper ignition timing. Not sure what is ECU though
