Klx250sf starting with choke on but dying when given throttle or taking choke off
Old Feb 20, 2019 | 07:19 PM
Brewster's Avatar
Where do you have the idle (pilot) mixture screw set to? It should be around 2 1/2 turns out. Adjusting the idle speed screw in opens the throttle plate a bit and reduces the affect of the idle mixture circuit. In that case, the carb is trying to operate on the main jet and needle circuit. The fuel from the idle circuit enters the air stream through a few tiny holes in the throttle bore right at the bottom of the closed throttle plate. My guess is that you still have a restriction in the idle circuit....pilot jet, idle mixture screw, or the fuel passages.
Ride on
Brewster
Ckahleer
Nov 21, 2011 06:26 PM
klx250s_rider
Jul 9, 2007 04:29 AM
pfft84
Ninja 250R
Aug 25, 2006 07:11 PM
Dallin
May 13, 2006 03:28 AM
