KLX250s WFI model - No spark
Old May 14, 2019 | 05:43 PM
peabrain's Avatar
ps i know i sounds dumb but maybe check your valves. (just to be shure)
Old May 14, 2019 | 09:44 PM
JPalma's Avatar
It's not dumb, but I had the top part of the engine disassembled because of piston rings stucked in piston grooves. It was repaired, and since then I made 200km until this problem started to happen. Plus I don't have spark, so even if valves aren't ok, something about ignition isn't aswell
Old May 16, 2019 | 09:16 PM
JPalma's Avatar
https://www.kawasakiforums.com/forum...tarting-41436/
try giving this a read and see if it helps
you may have a bad wire to one of the sensors, maybe look up a wire diagram and check the wires to them.
ps when cranking your battery sounds a little on the weak side( low cranking amps)
Thank you for this, this thread helped me findng the problem.
This are the cables that conect to ECU. The cables were damaged in the same place.
I fixed it, and right now the bike is running. Thank you all
Old May 16, 2019 | 09:56 PM
RA050924's Avatar
Banned
Glad you got to the bottom of it. And you didn't have to open up the cases or any major disassembly.
Tom Way
May 15, 2022 12:41 PM
scubiedoo22
Jul 17, 2019 05:17 PM
davebrodeur
KX65
Sep 13, 2009 07:54 PM
banger73
Ninja 250R
Sep 13, 2008 10:54 AM
iroc
Ninja 500R
16
Sep 2, 2007 03:30 PM
