KLX 250 ( 300 ) camshaft mod by Marcelino
Old May 20, 2016 | 01:29 AM
  #901
Josh128's Avatar
Im familiar with your document, thanks-- but have the dyno runs been completely erased off the net? The links in the first few posts no longer work.
If its no longer available, could you describe how the curve looks compared to the stocker shown below?
Old May 20, 2016 | 04:10 PM
  #902
Klxster's Avatar
The charts, therefore the "proof" you're looking for, are gone, as far as I can tell.. If you have the skills to do the MCM, you'll be doing it based on what you read in here.. While the loss of the pics is of no concern to those of us that have first hand knowledge of MCM gains, you should know that there was never a "before and after" chart ..
Old May 20, 2016 | 04:21 PM
  #903
Klxster's Avatar
Josh, you can read my DGR thread below for the recipe to get nearly 22hp/16trq (SAE Corrected @ rear wheel) instead of the 15.5-16hp you have now ..
Your link isn't working - We badly need a good Dyno Chart ( Actual chart with all supporting data) on a stockbore..
Old May 21, 2016 | 01:27 PM
  #904
zomby woof's Avatar
Which is what makes his posted charts completely erroneous.
Old May 22, 2016 | 02:19 AM
  #905
Josh128's Avatar
Zomby, Ive read a few of your posts. You sound skeptical--have you tried the timing adjustment personally? Whether you have or havent, what are your honest thoughts on the theory behind it and the real world results that most people who do it claim it produces?
Thanks
Old May 22, 2016 | 05:52 AM
  #906
Ruggybuggy's Avatar
Thanks
I does work but if you have no mechanical skills don't attempted. Valves and pistons meeting is not a good thing. I ran the MCM for about 6 months with no issues and good improvement in performance before I went with the BB 351.
Old May 22, 2016 | 09:12 PM
  #907
Josh128's Avatar
So I checked my Mojave service manual and saw this interesting information:
Mojave Valve Timing -
Inlet Open: 31 deg BTDC
Inlet Close: 53 deg ABDC
Duration: 264 deg
Exhaust Open: 57 deg BBDC
Exhaust Close: 27 deg ATDC
Duration: 264
KLX 250s Valve Timing -
Inlet Open: 22 deg BTDC
Inlet Close: 62 deg ABDC
Duration: 264 deg
Exhaust Open: 61 deg BBDC
Exhaust Close: 19 deg ATDC
Duration: 260
Looks like the Mojave inlet opens 9 degrees before the klx, closes 10 degrees before. The exhaust opens 4 degrees after the klx, closes 7 degrees after. So the Mojave inlets timing is advanced and the exhaust is retarded in comparison to the KLX. Sound familiar?
Below are spec scans for each machine for reference.
Size:  52.5 KBName:  ghAWdPPl.jpg
Old May 22, 2016 | 10:34 PM
  #908
Ruggybuggy's Avatar
Same 250? Shows a different bore and stroke.
Old May 22, 2016 | 11:08 PM
  #909
Klxster's Avatar
So, MCM is similar to stock KSF.. Don't know why this is important but it is interesting..
Old May 22, 2016 | 11:51 PM
  #910
KLXter and I both are running the Marcelino mod.
Any of you wonder if that 74mm piston would fit in the KLX? That is how I ended up with the 678cc KLX650 - Vulcan piston was 2mm bigger. Wonder how much liner metal is in there or is the 250 a plated bore.
