KLX 250 ( 300 ) camshaft mod by Marcelino
Old Nov 17, 2020 | 04:46 PM
  #1111
donhoolio's Avatar
Originally Posted by Jesse Curtis
Hey,
I plan on doing the cam mod soon, everything has been explained really well so I don't see any issues there.
One question I do have is "Should" the cams be removed to perform the mod, my concern is the torquing down of the cam gear bolts potentially harming the cam bearing surface when the pressure is applied?
If it's a non issue i'd rather complete the mod with the cams in the head.
Cheers
No, you don’t remove the cams, just the cam sprocket bolts. Set the piston to top dead Center using the timing marks on the magneto, Remove the cam chain tensioner bolt first, remove cam sprocket bolts(don’t drop)(do one sprocket at a time), wiggle off sprockets one at a time, ‘walk’ into position. A little fiddly, a little tight but doable.
Old Nov 17, 2020 | 09:13 PM
  #1112
Won't hurt the cam journals, plus the torque is relatively low due to the size of the fastener. I will say I did my adjustment off the bike, because I figured with my luck I'd drop one of the bolts in the engine . I loosened them while in the head, then pulled them and took the sprockets loose moving them and putting the bolts back in before putting the cams back in, then torquing them while in the bike. I was also adjusting the valve shims so I had to take the cams out anyway. I just don't trust my butter fingers...
Old Nov 17, 2020 | 09:42 PM
  #1113
Jesse Curtis's Avatar
Excellent thanks for info!!
Now to pull the carb first and see whats been done by the previous owner to make sure I don't make any minor issues worse
Old Nov 17, 2020 | 10:31 PM
  #1114
Tensioner on its way this afternoon, should see it in 3 to 4 days.
Old Nov 18, 2020 | 12:19 AM
  #1115
I just saw that email.
After my ride on Sunday I'm really looking forward to installing that tensioner!!
thanks again!!
Old Nov 18, 2020 | 12:22 AM
  #1116
Just saw the email.
Looking forward to installing the tensioner after last Sunday's ride.
Thanks again!!!
Old Nov 18, 2020 | 01:39 PM
  #1117
Thanks klx678!!
I saw that email last night and looking forward to installing it
Old Nov 30, 2020 | 06:00 AM
  #1118
Laika's Avatar
I've removed the CCT, but there is still no play in my camchain, is that normal? mine is 2013 EFI with 5000kms
now I'm stuck since its reallyreallyreally hard to nudge the gear out since there is no slack in the chain, anyway my cam chain would rattle really hard @ 5-6k rpms tho
Old Dec 2, 2020 | 05:14 PM
  #1119
Mateja's Avatar
You can try removing the sub chain tensioner, then you will have enough chain slack.
Old Dec 2, 2020 | 09:52 PM
  #1120
I'd look somewhere else. Without a tensioner there should be a lot of play in the cam chain.
